Clutch cable????
  • pepper0315
    • Sep 2005
    • 9
    • Cold Lake, AB Canada
    Clutch cable????
    So while movin my new 1984 XJ100, I may have broken a cable off the back of the clutch area of the handle bar. It's not the actual clutch cable, but what I'm guessing is perhaps a clutch sensor or something?
    Any thoughts?
  • lars
    • Aug 2004
    • 23
    • Norway
    Yes, that is a switch. Its there so you cant start the motor in gear without the clutch pulled in.
    A good thing, till you breake it.....
    • andreashweiss
      • 951
      If you cannot find one in your area I have one of those switches. e-mail to andreashweiss@yahoo.com
      • chevy45412001
        • Mar 2003
        • 1412
        • Jacksonville Florida
        ground
        twist both wires together and attatch to ground. the bike will run. BUT REMEMBER IT WILL START IN GEAR!!!!!!!SO always pull in the clutch when starting i think it's a good habbit anyway...
        1982 XJ 1100
        • pepper0315
          • Sep 2005
          • 9
          So this won't prevent the bike from running will it?
          • chevy45412001
            • Mar 2003
            • 1412
            mine runs
            it worked on my bike. I've had it like this for about 3 years now. i got the xj when switch went away i took the two wires that go to it bared the ends and wrapped them around the air fill cap on my front forks. been running ever since.Again use xstreme caution,if the bike is in gear it will be able to start AND REAP HAVOIC,IF your new to biking just replace the switch....andrea has one to get rid of..MUCH SAFER TO GO THAT ROUTE...
            1982 XJ 1100
            • chevy45412001
              • Mar 2003
              • 1412
              sorry
              sorry i think i miss under stood you. Yes if that switch is munked up your bike will NOT run. It is a saftey switch so your bike will not start without the clutch being pulled in.
              1982 XJ 1100
              • pepper0315
                • Sep 2005
                • 9
                In neutral it doesn't matter though does it?
                • chevy45412001
                  • Mar 2003
                  • 1412
                  not sure
                  i think if that switch is hooked up it has to be pulled in to start the bike. someone correct me if i'm wrong here.
                  1982 XJ 1100
                  • lars
                    • Aug 2004
                    • 23
                    • Norway
                    Yes, it will start if that switch dont work, but only in neutral, since you dont have to touch the clutch then.
                    Hey, chevy, saw your new van someplace in here, nice Maybe i should cut a little in my beauville
