Wirring Speedo
  • corey
    • Mar 2005
    • 208
    • Dexter, MO
    Wirring Speedo
    My 79SF has recently developed a whinning/wirring noise from the speedometer. The guage still functions correctly, its just annoying. I figure its try, maybe... but then I read that there isn't much to lube inside the speedo itself (I'm quite positive the noise is coming from the speedometer itself).
    Any thoughts?
    Corey J. Bennett
    '79 XS1100SF
  • randy
    • Dec 2003
    • 4521
    It's probably the cable. Try lubing it or replacing it.
    • Targetman
      • Feb 2003
      • 130
      • Oshawa Ontario Canada
      I was on a two hour drive last year when my speedo started making the same noise. Was a very loud squeeling noise.
      Eventually the speedo locked up inside and the cable broke.
      Had to find a used speedo at wrecker.
      My advice would be to disconnect the cable now, so that you don't have to buy a new cable when it locks up on you.
      Then find yourself a new/used guage.
      You could try taking yours apart and lubing it, but from what I've seen, finding another one is alot less bother.
      Good luck anyway....
      1979 xs1100sf
      1972 cb500 four
      • xs650mike
        • 1286
        • Lake County, California
        Speedo interchangebility
        If you can't find a 160mph "XS1100SF" speedo your SF can use any Yammie Special speedo including the 140mph speedo from an XS750, the 120mph from an XS650 or the 85mph "EPA" speedo from any '80 and up Special of whatever size, even the 400.
        Shiny side up,
        650 Mike
        XS1100SF "Rusty", runs great, 96k miles
        XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
        Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
          Try disconnecting the cable, and use a tywrap to keep it close to in place. A quick ride should tell you if it's the cable or the speedo. No noise, get a speedo. Noise, replace the cable.
          I would just get a complete cable if it's the problem. Once it starts making noise, the inner wall may take out a new inner cable.
          Ray
            You can attach the drive end of the cable in a reversable drill and run it in reverse to drive the cable, and speedo. You may be able to trouble shoot the problem that way. I was able to get the speedo to register 40 mph with a drill driving it.
