XJ11 90-degree parts?
  • JonInDenver
    • Aug 2004
    • 9
    • Denver
    As many of you know I transformed my XJ11 into a 3-wheeler. After about 4000 miles, I came to a grinding halt. I am able to run the bike in nuetral, and easily click it into 1st gear. But while easing out the clutch you can feel that it's bound-up somehow and the shaft won't rotate.
    My guess (an uneducated one) is that I've bungled the 90-degree drive aperatus that lies after the gear box.
    If anyone has any ideas of the probable cause, and if parts are available, please drop me an e-mail at Owriters (at) aol (dot) com. I don't get to check the boards often, but have access to e-mail.
    All ideas and suggestions are appreciated.
  • pggg
    • 1609
    • NZ
    Jon, the centre bolt on one of my XS11's snapped clean in half once. It's the one on the left in the pic. Maybe that's what's happened? I fixed it by using a thinner washer and locktiting the nut back on as best I could. Ran it like that for a couple of years with no problems. Possibly the U-joint is shagged too?
    • JonInDenver
      • Aug 2004
      • 9
      • Denver
      90-degree
      when that center bolt broke, did the gears turn like crazy but with no movement? on mine, nothing past the engine is able to turn.
      • chevy45412001
        • Mar 2003
        • 1412
        • Jacksonville Florida
        mid gear box
        i'd lay money on the mid gear unit. My gave way driving down the road,nearly threw me over the handle bars at 30 mph.to check remove the bolts that hold the drive shaft to it,and push bike forward.if bike moves freely then try to turn the output of the mid gear while tranny in neutral.
        1982 XJ 1100
        • JonInDenver
          • Aug 2004
          • 9
          • Denver
          mid-gear
          yup, slowed down at an intersection, came to a stop, and never moved again. in neutral, the driveshaft won't turn.
          any suggestions on a fix?
          • pggg
            • 1609
            • NZ
            When that bolt snapped, the driveshaft slopped around and jammed hard in the swingarm and locked up the back wheel. Happened mid corner The engine, gearbox, and mid drive still rotated but no power to back wheel. Had to peel back the rubber boot and lever the shaft free. Could then push the bike along the road.
              Hey John, and Pggg,
              What's that old saying, when you hear hoofprints, don't go looking for Zebras! The most common malady is the burning up of the middle gear bearings, and hence the lockup. John, you need to do some diagnostics to ruleout the middle gear vs. the rear Final Drive. Then, you can get a replacement Middle Gear assembly for under $100....I know AndrewWeiss just posted in the Member's Forum that he has several available, a relatively simple bolt off and on swap! But you'll need to do maintainance on it re: changing the fluid and then monitoring it closely! Your trike design/mod may have put more stress on it than it normally gets with just the single rear wheel!?
              cc to Email.
              • xj11yamaha
                • Jun 2004
                • 80
                • Northen Michigan, USA
                hey jon, i sent you a pm, but in case you didnt check your PM's then anyways, What type of rear end did you use for your trike conversion. What did it come out of. Thanks!
                Current Projects:
                -1982-1992 Yamaha Ezgo XJ1100 Maxim Project
                • pggg
                  • 1609
                  • NZ
                  TC, when we hear hooves, we look out for lions! Does sound like the drive unit self destructed inside.
                  • pggg
                    • 1609
                    • NZ
                    Jon, any chance of seeing some pics of that trikes rear end? I've rigged up a chaindrive rear from Kawasaki sportbike parts. Just a bike not a trike. Am just waiting on a couple of parts before it all gets bolted on. Those pinion gears can't handle any wear or misalignment - one of the Europe guys drive unit crapped out because of previous bearing trouble. Chewed all the teeth up!
