vacuum diaphragm
    boone;
    If you do go the rebuild route, clean everything!! I recall from another thread that there is a bleed hole that MUST be cleaned, or the fuel will not shut off. There is a VERY small hole on the opposite side of the diaphram from the vacum. If it plugs, once the fuel is running, it won't shut down.
    • boone
      • Feb 2005
      • 59
      • Kent, WA.
      Thank for the heads up. I'm going to tear into it this weekend. I think I have enough info to look at it.
      boone
      "Don't look at me in that tone of voice."
      1977 Pontiac Trans Am SE
      1980 Yamaha 1100 Midnight Special
      2001 Chevrolet Silverado
      • xjguy
        • Aug 2002
        • 93
        • georgia
        my octpus was leaking between the mating surfaces
        i checked diaphram and it was good
        so i resurfaced the 2 halves on 400 grit paper taped to sheet of glass- this got them back to square
