Hazard Flashers
+ More Options
Posts
  • noeleo
    • Aug 2004
    • 52
    • Batesville, Arkansas
    Hazard Flashers
    Can't seem to get my hazard flashers to work. Have tried everything I can think of, and can't figure out what I'm missing. Any suggestions? Thanks
    Midnight Rider
    1980 XS1100LG
    Intruder Alert!!!
    2002 Suzuki Intruder VS800GL
    XSive rules. Ride it like you stole it, unless it's mine. Then just PUTT, PUTT, PUTT!!!
    Happy XSing
    The hazard flasher is a separate flasher unit than the turn signals, and it may be bad!? IT's only 2 prong unit, and can be replaced with a standard auto 2 prong type. It's round, and I think under the seat, inbetween the frame rails!?
    But also could be corrosion in the handlebar switch, but I'd check the flasher first!
    • LoserShoes
      • Apr 2005
      • 524
      • Bangor Maine
      On mine it was the handlebar switch, with the switch on the bottom of the bar, it lets all kinds water and bugs in. One contact was so corroded that the wire just fell off when I took mine apart.
      Take it apart carefully and keep track of the small bits.
      Steve
      80 XS1100G Standard - YammerHammer
      73 Yamaha DT3 - DirtyHairy
      62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
      Norton Electra - future restore
      CZ 400 MX'er
      68 Ducati Scrambler
      RC Planes and Helis
      • noeleo
        • Aug 2004
        • 52
        Thanks for the replies. Took apart the switch, and BINGO. There was the problem. Cleaned it up, and now they work just fine. Appreciate all your help, guys. Thanks
        Midnight Rider
        1980 XS1100LG
        Intruder Alert!!!
        Happy XSing
        • DeanR
          • Jan 2005
          • 1486
          • Finger Lakes NY
          My hazards haven't worked either. So I'm in my switch housing right now, looks good except 3 wires are loose from the hazard switch. Don't know if they have been that way right along or if they broke free as I was getting in there. Anyway I can't tell which goes where. They are brown, brown/yellow, and brown white. All right next to each other. Do you guys know which order they connect? THANKS
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
          • DeanR
            • Jan 2005
            • 1486
            • Finger Lakes NY
            Hey guys, just figured out the connections. By process of elimination got them working. Now I just have to figure out how to solder the connections with a soldering kit I don't think I've ever used. Can't be that hard. Any tips? Thanks again
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • LoserShoes
              • Apr 2005
              • 524
              • Bangor Maine
              Clean everything good with some fine sandpaper and use a good flux like Nocorode and solid core solder, rosin core doesn't work to well for this sort of thing. Use enough heat to get a good flow on the solder. The mid range Weller soldering gun is enough, not sure of the heat range offhand, but like 50 - 60 watts.
              If I remeber right, the contacts like a copper rivet, and the wires solder into a hole in bottom of them, you should put a little flux in them, heat them and shake out the old solder, that will make it easier to make the new solder joint.
              Steve
              CZ 400 MX'er
              68 Ducati Scrambler
              RC Planes and Helis
              • DeanR
                • Jan 2005
                • 1486
                • Finger Lakes NY
                Hi Steve, This soldering gun looks to big for this job but its all I have (Weller 100/140 watts). One tip is smaller than the other but those round contact points are pretty small. Is the plastic housing in jeopardy of some melting if I can't do it precisely enough? Everything is cleaned off well. Still have to get some solder and I did notice that some has the flux right in it. As I think about it, can't believe I've never needed to solder anything! Appreciate the advice!
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  Plastic should be fine if you don't touch it directly with the tip. Put little flux on first and flow the old solder to get rid of all the old oxides that have formed. You can always turn the gun on and off if you think its too getting too hot. If everything is good and clean it will flow on easy and not be a problen. Melt the solder with the joint , not the iron. Make sure the tip is well tinned, touch the solder with the hot tip and it should flow onto the tip. Don't rush it and maybe practice on something else first.
                  Steve
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                  • DeanR
                    • Jan 2005
                    • 1486
                    • Finger Lakes NY
                    Talk about feeling stupid. Can't get this solder deal to work, even on practice wire and similar looking rivets on a light switch with a smaller tip soldering iron I came up with. I have the stuff that says it is for electronic work, not plumbing. It is the resin core. Steve, you said melt the solder with the joint not the tip. Not sure how to do that with everything right next to each other, and the plastic sheathing on the wire gets to hot to hold. It won't make the connection. I must be missing something, like talent.
                    Any more advise? Thanks a bunch
                    80 SG
                    81 SH in parts
                    99 ST1100
                    91 ST1100
                    • DeanR
                      • Jan 2005
                      • 1486
                      • Finger Lakes NY
                      Just needed a little more patience and practice I guess.
                      Everything's back together and working!
                      A little vise grip helped a lot.
                      Thanks
                      80 SG
                      81 SH in parts
                      99 ST1100
                      91 ST1100
                      • LoserShoes
                        • Apr 2005
                        • 524
                        • Bangor Maine
                        Yup, just takes a little practice and patience.
                        Steve
                        CZ 400 MX'er
                        68 Ducati Scrambler
                        RC Planes and Helis
