oil cooler hoses needed $$$$$$$
  • gaffer77
    • Jul 2004
    • 444
    • gloucestershire england
    Hi i need the 2 brackets to hold the cooler pipes to the frame ,i got the round ones on the hoses just need the 2 that they attatch to and then mount to the engine mounts on the frame.
    looking for original so dont want to fabricate any
    will pay $30.00 FOR 2 GOOD UNNS!!
    OR SWAP SOMETHING i have allot of xs bits and pieces
    thanx for reading this!!
    Don't put all yer eggs into one basket ,,,case
  • pggg
    • 1609
    • NZ
    Gaff, 2 small bolts/nuts, an empty baked beans can, a drill, a pair of tinsnips and a squirt of paint. 2 strips 2cm x 10cm. As for original - I wont tell if you dont.
    • gaffer77
      • Jul 2004
      • 444
      Just a shame to do it when its something so stupid
      Tryin to get it all back original as poss
      got a fetish for it!! like the challenge of finding the bits as well!!
      • rickmcdougald
        • Jan 2005
        • 97
        • Corvallis, Oregon
        Hey Gaffer,
        Can you send us a picture of the items that you want to secure together?
        RLMcD
        XJ1100J Maxim (Arlington)
        Ruby Red
        XS1100E (no name yet)
        Macho Maroon
        • gaffer77
          • Jul 2004
          • 444
          IN the picture you will see the small brackets i need
          they have a top and bottom hole,they are a T shape
          the ' T ' shape is only about 1.5 inches long the tab fixes to
          a round clip with a tab on it which is connected to the hose
          I got the ones on the hoses
          The reason i don't want to fabricate is because these are shaped
          to angles to the frame and they pull the hoses tight in and away from the exhaust down pipes JUST!!!!
          part of an engine mount may do it ,just got to get one to see???
          • pggg
            • 1609
            • NZ
            Gaff, if you have no luck, the T's will be very easy to snip from 1mm tin plate - flexible to bend an angle on & still stiff. There are a pair of upper tabs too. (the ones I described previous) 1mm plate would be preferable to a baked bean tin though!
            • gaffer77
              • Jul 2004
              • 444
              Hi i got four round clips on the hoses
              ,,where do the top ones attatch to??
              think i will make some and see how they look
              only putting a cooler on as the bike looks wierd with a big gap!!
