i hope someone has a idea that can help me , i had my rear wheel lock up on me twce when i let off the gas and heard a grinding sound before it let loose again i checked the rear wheel and final gear and found nothing wrong and the transmission shifts fine unless your really pounding on it and then second would like to pop out , i sure could use some help here
locked up rear wheel
Tags: None
Sounds like the problem could be a dry middle-drive unit.Strom has just discovered this problem in his ride too - look at this thread
Ouch!Ken Talbot -
Originally posted by timberwolf57
man i hope this isnt that bad , but i will chaeck that out tomorrow and see
thanks timberwolf
timberwolfComment
This is good news, I think. At least your middle and final drives sound like they're okay.
Another thing that can cause rear wheel lock-up is the rear brake, but I would think that would have been obvious. It is more likely for the rear brake, or one of the fronts for that matter, to drag and get severely hot rather than grab on all at once and lock up the wheel.
Before you drop the oil pan, pick up a gasket or have some gasket material on hand. The pan is easy enmough to remove, but you will probalby tear the gasket doing it.Ken TalbotComment
I've heard of clutches causing the back wheel to lock up. But that's only been after the plates had sat for a while without being immersed in oil. If this is your case, then perhaps the friction plates are grabbing intermittently? I'm probably way off base, but its something else to wrap your mind around...Corey J. Bennett
'79 XS1100SFComment
