Brake light bulb
  • teck_mountain
    • Aug 2003
    • 128
    • Red Deer, Alberta, Canada
    Brake light bulb
    On my last ride my brake light stuck to the on position. I'm thinking it's the bulb, even though it does not look burtout. (the base does seem to be burnt) However, I'm having a heck of a time finding one. The local canadian tire didn't seem to have any and my local yamaha dealership needs to order it.
    I'm having a hard time thinking that this is some special type of bulb. Any suggestion regarding what I could do?
    Tim Lowe
    "Teck"
    1979 xs1100 Special
    If the light stuck on, it's NOT the bulb. You have a brake light switch sticking. It is probably the rear light switch, as it's usually in the gunk and mud.
    I would turn on the ignition, and try to disconnect the rear brake light switch. Just unplug one of the wires, and see if the light goes out. If not, then look to the front switch. The two wires from it connect in the headlight housing. I would also check for a wire that is shorting on the headlight housing.
    • COOL TOM
      • Jul 2005
      • 288
      • CANTON, IL
      BRAKE LIGHT
      IF THE BULB WAS ON ALL THE TIME ONE OF YOUR BRAKE LIGHT SWITCHS IS STUCK ON. CHECK THEM FIRST. ALSO IF IS A BRAKE/TAIL LIGHT ANY 1157 OR 2357 BULB WILL WORK. IF IT IS BRAKE LIGHT ONLY THEN USE 1057 FROM ANY AUTO PARTS STORE
      Thanks Tom
      82 XJ DAILY RIDE
      78 XS1100E FIXING UP
      79 XS1100F PARTS BIKE
      79 XS1100SF NAKED BIKE
      80 XS1100SG FULL DRESS BIKE
      82 XJ IN THE ROUGH
      • teck_mountain
        • Aug 2003
        • 128
        tail light
        Okay I removed and cleaned the rear switch. Good newis that I got the break light to go off. However, now I cannot get it to go back on when I press either the front or back brake.
        any suggestions?
        Tim Lowe
        "Teck"
        1979 xs1100 Special
          Hey Teck,
          First, please edit your profile so we know what model/year your bike is!?
          Secondly, recheck the bulb, after being left on for so long, the filament may have gotten fried, and after turning off, etc., may have finally blown?
          Next, your front switch may have been bad for a while and you didn't know it? Take a jumper wire and pull the plug from the switches, and use the wire to jump/connect the two wires in the plug and see if the brake light comes on. If so, then possibly the switches have gotten fried and need replacing?
          Don't forget to check fuses? T.C.
          • COOL TOM
            • Jul 2005
            • 288
            • CANTON, IL
            TAILLIGHT
            KEY ON/ BIKE RUNNING. BULB IN TIGHT/RIGHT WAY, WIRE CONNECTED ON SWITCH/LOOSE CONNECTION.
            Thanks Tom
            82 XJ DAILY RIDE
            82 XJ IN THE ROUGH
            • teck_mountain
              • Aug 2003
              • 128
              Tail light issue
              Hello all
              This is getting frustrating. Pulled and cleaned both switches and tested to see if a power was passing. Both passed. However, the tail light remains on, but the brake light will not come on. I put one switch on at a time and still nothing. check all fuses all are good. new bulb. tried with the bike running and off.
              Help!
              Tim Lowe
              "Teck"
              1979 xs1100 Special
              • John
                • 5117
                Stupid question time
                Do you have the bulb in backwards? It can be done, and by doing that, the dimmer filiment of the bulb won't be seen over the brighter one that should be for the brake light. Have you unplugged the wiring at the tail light assy and tested for power there?
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  On either switch, assuming you have a 78-79, there is a brown wire and a green/white wire. Jumper the green/white to 12volts and the bulb should turn on. If not there is break in wire some where between the switch and bulb.
                  If that works, jumper from the brown to green/white. If the bulb turns on then the switch is bad. If it dosn't, there is a bad connection in the brown wire.
                  The brown wire supplies 12v to the switch, and when the switch closes the green/white connects the 12v to the bulb which is grounded at the tail light assembly.
                  Steve
                  80 XS1100G Standard - YammerHammer
                  73 Yamaha DT3 - DirtyHairy
                  62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
                  Norton Electra - future restore
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                  • randy
                    • Dec 2003
                    • 4521
                    Teck,
                    Pull your seat. There's a multi-pin connector under there near the TCI. IIRC, 9 pins. It feeds the entire tail assembly. Clean it.
