final drive plug problem
  • DeanR
    • Jan 2005
    • 1486
    • Finger Lakes NY
    Any suggestions on what to do when the hex drive starts to round off in the plug. Can't free it up to check fluid level. This also happened a few months ago on middle drive but I was able to get a vise grip on it. Not enough lip to grab on this one! Thanks
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • superdave
    • 69
    • mpls, mn.
    stuck plug
    Hit it with a hammer, the old harley davidson performance tool. hit it flat and true,thats what I did to break it free. And get a new allen wrench.
      You might also be able to get at it with a good pair of slip-joint pliers - some with fresh, sharp teeth on the jaws. Be sure to throw on a fresh crush washer before you reinstall the plug.
      • Hobbit
        • Nov 2002
        • 372
        • Jacksonville, FL
        plug
        I recommend putting some abrasive compound (like valve lapping compound into the allen hole and then using a hand impact driver to loosen the plug.
        I don't know how I'd get anything apart on these bikes without the impact driver.
        There's a photo of one near the bottom of this page:
        Tere are inexpensive and they work great.
        Walt
        80 XS11s - "Landshark"
        79 XS11s
        03 Valkyrie
        80 XS Midnight Special - Freebee 1
        78 Honda CB125C - Freebee 2
        81 Suzuki 850L - Freebee 3
        • DeanR
          • Jan 2005
          • 1486
          • Finger Lakes NY
          Hammer and chisel did to break it free. That was easy!
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
            Now go to a nut and bolt supply shop or a hardware store and buy a new plug, Use thread thread tape or pipe dope on the threads to prevent oil seeping around the threads and you won't have to put the 'Gorrilla tight' on the plug when retighening.
            • fxrer
              • Aug 2004
              • 241
              • Bethlehem, PA 18017
              I posted on this back in May, and there are many earlier threads on this subject, i.e., hard to remove final and middle plugs. I found a hex head automobile replacement plug at Advance Auto parts that works fine, with a little modification. Go here to see the plug.
              Rick
              '80 SG
              '88 FXR
              '66 Spitfire MK II
              • desert1
                • 750
                • Grand Desert, Nova Scotia, Can.
                Washers?
                See where Ken mentioned putting on fresh washers on the plug but neither my final gear or rear drive unit plugs ever had washers on them since I've owned the bike...does everyone else have washers? are they metal, plastic or fiber?
                Bruce
                perplexed
                Bruce Doucette
                Phone #1 902 827 3217
                  They can be copper or fiber or plastic. Just like the ones on your car. I also use thread tape on mine, as I use synthetic gear oil and it will creep out by the threads of the plugs,
                  • pggg
                    • 1609
                    • NZ
                    Sparkplug washer fits good.
                      • 5050
                      I have developed a fondness to using nylon washers, although I havent used them on the middle gear drain plug yet. You don't have to torque them so much to seal, they do not melt (haven't melted on the crank case oil plug or filler plugs on middle and final gear cases), and they are much easier to get that plug out later!
                      • LoHo
                        • Sep 2002
                        • 1341
                        • Fresno, CA
                        I replaced my stripped out hex heads with some metric oil plug replacements with a raised six-point hex, so I can use a socket on it. I had to grind off a little of the flange around the final drive plug to get it to fit. I'll send pics if you'd like...
                          Bruce, have you looked really close at your middle and final drive filler plugs? With good light and magnification? I've seen those crush washers get so flattened you'd swear thay were part of the plug itself. Even with my fairly recent progressive prescription, I couldn't make out whether one of the plugs on SWMBO's still had a crush washer or not. Turned out it did, but it was so flat it was useless. Good thing I was changing out sparkplugs at the same time so had a ready supply of new washers.
                          • Shuriken
                            • 1093
                            • Southwest USA
                            I used the allen wrench extended with a cheater bar and a hefty clamp with vise-grips. Turned both at the same time and it popped free. Take the bottom of the airbox off before you ever try to wrench on it and you'll have more room to work with.
                            I replaced the one on my old 80g with an OEM part.
                            Ben
                            Formerly:
                            1982 XS650
                            1980 XS1100g
                            1979 XS1100sf
                            1978 XS1100e donor
