No 1 and 4 being too tight would explain the 'popping' I get at idle out the left side. I have the Jardine 'spagetti pipes' and 1 & 4 run to the left side. Also, the engine dosen't drop to idle as fast as it should (little 'engine braking').
78 specs are Int .16mm - .20mm and Exh .21mm - .24mm.
Guess I'll be using the valve tool that was in the bucket of stuff that came with the bike. Yamaha original tool, not the Motion Pro.
This is the 1st project in my new shop
. 12' x 17' that I've insulated with 3/4" foam insulation. Roll-up door on one end, sliding door on the other end. Over the insulation will be peg-board so I can hang stuff all over the place.
