Hello XS Gods. I bow before you with a request.
I am fairly mechanically inclined, but I have never really worked on a bike like this.
I have an 81 xs1100 Eleven Special.
Here is my problem. It starts relatively easy, but I have to allow it to run for several minutes before I can throttle it. The big thing that is fouling me is that once you do get it going, it seems to get real hot on the right side and the exhaust from that side seems to be a lot warmer then off the left side. And as you begin to come off idle it back fire (to the best that I can determine the backfiring is coming from the right side to.) Now at first I thought it might be the carbs, but above 2500- 3000 rpms it smooths out okay. I have ridden the bike once so far and it seems to pull just fine.
My question is, could it be the timing? Or is it the carbs? I am still digging thru my new clymer's manual but I have yet to find anything that addresses this. The only other thing is that there is a strong gas odor and when it idles rough, if I set it to prime it seems to smooth out a bit.
Now I am not sure how the carbs are set up, to my knowledge they are still stock settings, since everything I have seen on it so far is stock. I have not replaced the plugs yet but have inspected them. The plugs on the right side seem to have a bit of a gray carbonish type stuff on them, which I believe is from the hot running. ((Correct me please if I am wrong.)
Thanks folks,
David
Thanks folks,
David
I have the same bike. You didn't tell us how you got the bike or how long you've had it!! Had it been sitting a good while before you got it? Well, like Mike Hart said, the fuel system on these things can be real buggy, and you need to make sure that there isn't any fuel in the oil first, otherwise the engine can be damaged very quickly if you keep riding it that way. Take the oil filler cap off and take a whiff, if you smell gas and not just oil, then there is a good chance it got past your carbs float needle valves, and trickled thru the carb throat, past an open engine valve, around the rings and down into the engine.
