Hello XS Gods. I bow before you with a request.
I am fairly mechanically inclined, but I have never really worked on a bike like this.
I have an 81 xs1100 Eleven Special.
Here is my problem. It starts relatively easy, but I have to allow it to run for several minutes before I can throttle it. The big thing that is fouling me is that once you do get it going, it seems to get real hot on the right side and the exhaust from that side seems to be a lot warmer then off the left side. And as you begin to come off idle it back fire (to the best that I can determine the backfiring is coming from the right side to.) Now at first I thought it might be the carbs, but above 2500- 3000 rpms it smooths out okay. I have ridden the bike once so far and it seems to pull just fine.
My question is, could it be the timing? Or is it the carbs? I am still digging thru my new clymer's manual but I have yet to find anything that addresses this. The only other thing is that there is a strong gas odor and when it idles rough, if I set it to prime it seems to smooth out a bit.
Now I am not sure how the carbs are set up, to my knowledge they are still stock settings, since everything I have seen on it so far is stock. I have not replaced the plugs yet but have inspected them. The plugs on the right side seem to have a bit of a gray carbonish type stuff on them, which I believe is from the hot running. ((Correct me please if I am wrong.)
Thanks folks,
David
Thanks folks,
David
