Oil cooler
  • MAXIMAN
    • Jan 2005
    • 1817
    Louis
    Hey your engine looks great. Good paint job.
    The Cooler is a B&M Supercooler 70265. Got it at NAPA.
    The thermostatic valve was purchased from Summit Racing online. I had originally bought a B&M 70259 thermostat but it had the 1/2 connectors. I wanted 3/8 so I found one at Summit's website. However the B&M would work fine and you get those at NAPA.
    Both were about $85 I think.
    • gaffer77
      • Jul 2004
      • 444
      • gloucestershire england
      just put a cooler on ebay
      seen 2 lockharts on ebay lately (nos)
      look real nice!!
      Don't put all yer eggs into one basket ,,,case
      • MAXIMAN
        • Jan 2005
        • 1817
        A good friend told me to get the Lockhart 600 if I could. It has a much higher BTU exchange rate. I think the Lockhart maybe fin and tube type.
        This B&M Supercooler is a plate type exchanger and gets rid of heat more efficiently...least that's what I've read.
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          I would think (just pondering again) that for a typical motorcycle application, oil cooler behind the forks, that the "tube and fin" would be better.
          "Tube and fin" would allow air to pass through and continue over the engine (or cylinder head). The plate type could block airflow.
          Seems the plate type would be better when mounted with the airflow moving across it as opposed to straight into it.
          I'm not that familiar with the plate type so I may be wrong.
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
          • MAXIMAN
            • Jan 2005
            • 1817
            No not really. The plate type allows air flow through it as well as T&F. But the effective cooling surface area of the exchanger is much larger even though the size of the radiator is same.
            The way this is achieved (it appears to me) the plates aren't really plates but almost look like tubes that have been flattened thus creating a "Hollow" fin of sorts that the hot oil flows through. The fluid in the flattened tube is exposed to more exchange surface and thus cooling medium (air) due to the geometry of the core.
            A tube and fine is simply a round tube with heat dispersing fin wrapped around the tube. Fluid only flows through the tube and not the fin. For some reason (I'm not a mechanical engineer) this type of exchanger doesn't get rid of the heat as efficiently as a "plate type". It appears to be due to these two facts:
            1-the the plate or flattened tube spreads the fluid over a larger area for heat dispersion.
            2-the plate also acts as the fin in and of itself so there is more direct contact between the oil and the cooling medium (namely air).
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              That makes sense
              Pat Kelly
              • MAXIMAN
                • Jan 2005
                • 1817
                Well I dunno about that. I'm not much at explanations.
                But if you get a chance look at one. I know you can find it on the web....or go to an auto parts store and look at the difference. It's real obvious how they work when you see 'em in person.
                • planedick
                  • Mar 2005
                  • 2068
                  • Yorba Linda, California
                  Oil cooler....
                  Well, I don't expect any problem finding an oil cooler, but I'm still looking for an adaptor that goes under the filter so I have a place to hook it up. Does anyone know where I can get one?
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  Custom security system
                  Stainless braid brake lines
                  • Cykotic
                    • Jun 2005
                    • 25
                    • Central Valley, Ca.
                    Mine has an oil cooler, 1981 xs1000h, but i thought it was a stock part, guess i was wrong, but i seems to work great. I'll try to find out more about it if i can.
                      The H model came from the factory with an oil cooler, as it was a full blown touring model.
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        There has also been mention of running cooler lines from the oil feed tube at the back of the head/cylinders. Do a search of the forum and read the pros and cons of tapping into this area.
                        Pat Kelly
                        • planedick
                          • Mar 2005
                          • 2068
                          Oil lines
                          Pat, the oil lines to the head would work only just a little because the volume moving through the cooler is limited to just what goes through the bearings, so the flow would be very minimal. I really need an adapter plate between the filter and case.
                          Dick
                          Drilled airbox
                          Tkat fork brace
                          Hardly mufflers
                          late model carbs
                          Newer style fuses
                          Oil pressure guage
                          • MAXIMAN
                            • Jan 2005
                            • 1817
                            Planedick
                            One more time. CALL OZ CYCLE SALVAGE
                            1- 785- 242- 0600
                            He WILL have one. I just sent one back to him a couple weeks ago and he said he could get more.[
                            • planedick
                              • Mar 2005
                              • 2068
                              OZ cycle parts...
                              I talked to the guy at the salvage yard in KS, he told me he would only sell the complete unit and I have already invested in the same cooler and regulator as Maximan shows in that photo of that beautiful machine. I am still in need of an adaptor plate and special nut. I'm sure I can make the plate, but I don't know about the special nut. Maybe when I get it apart so I can "eyeball it", I may be able to find or make a special nut. If anyone out there can sell me an adaptor plate and nut I would be forever grateful. This thing gets really hot in the So Cal heat.
                              Drilled airbox
                              Tkat fork brace
                              Hardly mufflers
                              late model carbs
                              Newer style fuses
                              Oil pressure guage
                                You'll be ok in the SoCal heat. It's the Texas, Oklahoma, Arizona and New Mexico heat that will get you. I had an old Yamaha TX750 backin the late 70's early 80's, and I was in the Navy In San Diego. I never had any heating problems. Granted, having one surley won't hurt anything either.
