I am looking to put an oil cooler on my bike and I was wondering if anyone had done that yet? I am interested in finding out where to connect it into the oil system without causing loss of oil pressure. I know you guys collectively have all the answers and maybe someone who does can help.
Oil cooler
Oil cooler
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesTags: None -
I lack any answers that may apply to your question, planedick, but it spurs me to ask a similar question (sorry to semi-jack your thread, BTW):
While we are on the subject of oil system modification, how about a filter adapter that allows the use of a standard car filter? I saw something on the forum about this a while back, but now I can't seem to find anything about it. Did we ever get a successful one going?Corey J. Bennett
'79 XS1100SF -
Oil cooler
Well, after I did this new thread I got smart and did a search. DUH That worked and I got a couple of instances of prior applications and some "don't do's". As for your question, I just read something about that. Look under "tech tips/modifications/oil&lubrication, you'll fine it there.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Stainless braid brake linesComment
planedick:
Yes there are oil coolers for the XS1100. Check Ebay as stock and aftermarket coolers pop-up all the time. Oil is usually routed to the cooler via a "sandwich plate" that goes between the engine and oil filter cup.
corey:
Same for the oil filter atapter. It bolts on in place of the oil filter cup.
I have a cooler on my E (and one that is to go on my LG). I also got the spin-on adapter but I felt the filter was too low to the ground. I sold the spin-on adapter. Others have used it with great success both with and without the oil cooler plate.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Hi, Pat, I did get your oil filter adapter on my F, and it works great. Thanx again for the trade. I can see that if you use it with a cooler, there could be a few problems. The only mod I made was to cut off an inch from the threaded pipe, there was a lot left over. I have done one oil change since I installed it, and still no leaks. What a difference to my hands and garage floor!!!!!!put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
76 CB 750 (gone to MC heaven)
rover has spokenComment
Hmmm..... I wonder if the two plates (oil cooler and spin-on adapter) could be combined into one plate?
I'm sure it could but at what co$t.Pat Kelly
Oil cooler adapter plate
Pat, where can I get one of those oil cooler adapter plates?You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Keep an eye on Ebay. XS750 and 850 will work too.
Wrecking yards may have them. I've had good luck with www.ricepaddymotorcycles.com .
Make sure you get the union nut that it mounts with or else it's useless (someone said they are available at most hardware stores). The nut replaces the oil filter bolt and holds on the plate. The oil filter bolt then screws into the nut.
The cooler on my E is a Lockhart aftermarket. I don't know if they are still in business or have a website.Pat Kelly
Planedick,
Call the salvage yards. I bought mine form a member here. Made a post requesting and within a day had a response. However I've found several at salvage yards. Try OZ in Ottowa, KS. He'll have one or can get it I guarantee.
Then I bought an oil cooler at NAPA. It was a plate type (not tube and fin). They exchange more efficiently. The one I got was polished...looks chrome. I also bought a thermostat from Hayden I believe NAPA too. Used SS Braided hoses. The thermostat starts opening at 160 and is fully opened at 180 degrees. I think the whole rig cost me about $200 or 250.
I added the stainless 3/8 tubing downsweeps from the cooler to the thermostat. You could use other means besides SS tubing I just wanted it to look professional.
Yeah well I searched high and lo for a Lockhart to no avail. They are really slick. But they don't make 'em anymore.
I found this one (Supercooler) at NAPA in their parts catalog. It's polished and looked like chrome (similar to some Lockharts I've seen). Another feature of the Lockhart I liked was the built in thermostat. So I bought a thermo since Lockhart is gone. I hear they sold out to Harley. It was Harley's main competitor regarding aftermarket coolers. I also heard once Harley bought the comp...they simply shut it down. It put no tellin how many people out of work. YET ANOTHER REASON TO HATE HARLEY DAVIDSON!Comment
Maxman,
Do you have part #'s for that cooler and thermostat?
Louis"There is no mechanical problem so difficult that it cannot be overcome by
brute strength and ignorance" And possibly some Mouse Milk!
'82 XJ1100J
LED Dir and running lights
LED Tail/Brake lights (4) one flashing
Modulated H/L
PIAA Driving lights
YICS Eliminated
750 FD
Yamaha Factory X-1 Fairing and LuggageComment
