info on 'safe starting' features needed
  • info on 'safe starting' features needed
    I need some help finding out which models/years have/don't have the following:
    • sidestand switch
    • clutch switch
    • neutral switch
    These work with each other to prevent the bike from starting if it is an 'unsafe' condition.
    Neutral switch - if bike is in neutral, it will start with clutch not pulled in and/or sidestand down.
    If the bike is NOT in neutral, then both the clutch must be pulled in and the sidestand up.
    The XJ has all three of these - I'd like to know which ones other models have. TIA
    Mike * Seattle * 82 F'n'XJ1100 *
    my 78E has the netural switch, and my 81 xs650 has netural and clutch switch
    Shawn
    78 XS1100E "Black Rat"
    78 XS1100E Parts
    www.hotrod1972.com
      Mike
      My 80SG only has a neutral!
      Norm Willey
      94 BMW K75RT
      nwilley@shaw.ca
        But my SG will lurch forward in gear with the clutch engaged, sidestand down. Don't tell me there's something funny about Crunchbird ?!
        My clutch cable snapped in town, so I got into first gear, and had to stop for one red light. Started up in gear and when she caught I was Ridin'.
        David Browne
        XS11SG Crunchbird
        XS500E
          I don't think that's right about XSs. I don't believe that any model came stock with a Neutral, sidestand or clutch interlock switch.
            I know my 78E has a neutral switch.. but I hell if I know where it is... any photos/description on where it is... the switch and cable should be located under the engine... I guess... any additional info welcome.
            Call me stupid, but I REALLY CANNOT FIND THE F*CKING SWITCH!
            no side or center stand switches... nor clutch switch...
            LP
              sorry JP, you don't win the toaster oven
              79SF Neutral Switch Ass'y 2H7-82540-00-00
              Come to think of it, how DOES that neutral light know when to come on??
              The 81H and 81SH fiche shows a clutch switch too!!
                80 Midnight Special,
                Neutral light switch, but no side-stand interlock or clutch switch.
                CUAgain,
                Daniel Meyer
                Author. Adventurer. Electrician.
                Find out why...It's About the Ride.
                  I think the XJ were the only ones with a side stand switch, and clutch interlock switch. My 80 has none of this hooey.....
                  Gary Granger
                    The XJ sidestand switch is indeed a 10M part #. H and SH have the neutral and clutch switch. (I'm guessing LH does too.)
                    Okay you E and F owners, you have a neutral light? Can you start your bike when it is in gear?
                    Hooey is right, the lawyers got ahold of the XJ team alright! Talk about overkill.
                      Are you saying/asking a neutral light switch or a neutral interlock switch - IOW if you're not in neutral you can't start the bike?
                      I don't believe any XS11 has a neutral interlock switch that would prevent you from starting the bike in gear.
                        I am asking. However....
                        The LH manual shows it indeed has both a neutral and clutch interlock, so there is some evidence that at least ONE model of XS does have the interlock.
                        The H/SH manual also has the same setup (called the Starter Circuit Cut-off system). Okay, I'm satisfied that all the 81's had both neutral and clutch interlocks.
                        I'd really like to know whether that was the first year for any interlock system.
                        • #13
                          Well, the 80 Midnight only has a neutral light switch, there is no interlock and it will start in gear (with the sidestand down and no clutch if you so desire)
                          CUAgain,
                          Daniel Meyer
                          • #14
                            On my 79F I DO have a neutral light (and switch), but it doesn't have any impact on starting the bike. I can start in gear with the clutch pulled, in neutral without the clutch pulled, side stand up or down. FWIW
                            Bill K.
                            1985 Yamaha XJ700 Maxim
                            1986 Yamaha FZX700 Fazer
                            • #15
                              switchs
                              My 80 XS1100LG Midnight Special has a neutral indicator switch but will start anytime. T.J.
                              And its a real thrill when you forget to put it into neutral when starting in the garage.
                              1980 XS1100LG Midnight Special "Widow Maker"
                              1999 Royal Star Tour Classic
                              T.J. Trahan
