Head light problem
  • kicker42
    • Jul 2005
    • 7
    • MI
    Head light problem
    My head light just went out. I checked the fuse it is good I checked the bulb it is good. I put a test light on the switch for high and low beem it is not getting power and the head light is not getting power eather. what should I check. I pulled aprt all the conections I could get to and sprayed them wit electical contact cleaner I tried to pinch the arms that hold the fuses in and broke one off now I need a fuse panel also.
  • Czekus21
    • 1069
    • Keosauqua (Southeast) Iowa
    Have you checked the reserve lighting relay/switch?
    S.R.Czekus
    1-big XS patch
    1-small XS/XJ patch
    1-XS/XJ owners pin.
    Just do it !!!!!
    • kicker42
      • Jul 2005
      • 7
      • MI
      Were is that and how do I check it. I know I need to get a manual for this bike.
      • Dragonrider
        • 1219
        • Garland, Texas
        The bike is running when you check, right?
        There is a headlight relay under the tank ... a square thing...that is intended to turn on the headlight when the engine is running.
        I would suspect that is the problem, if you're sure the fuses are good....
        CUAgain,
        Daniel Meyer
          • 5069
          Re: Head light problem
          Your tachometer is working, right? Your engine must run to fire the headlights (unless you have a 78E model). I would suspect either the headlight relay (under the tank, near the front), or perhaps a bad ground. Check continuity between the headlight ground and the frame. The reserve lighting unit can be bipassed if it is suspect.
          • corey
            • Mar 2005
            • 208
            • Dexter, MO
            It should be noted that the procedure for bypassing the Reserve Lighting Unit (RLU) can be found in the forum, under the Modifications section. The title says something like "How to Remove your RLU," or something to that extent.
            Also, it wouldn't hurt to do a forum search for "RLU" or "RLU bypass"... Good luck!
            Corey J. Bennett
            '79 XS1100SF
              • 5069
              Or, you can see some pictures here:
              Instead of cutting wires, you could probably jumper them.
              • corey
                • Mar 2005
                • 208
                • Dexter, MO
                I was going to mention skids sit, but I couldn't remember the URL off the top of my head. It helps a lot, check it out!
                Corey J. Bennett
                '79 XS1100SF
                • planedick
                  • Mar 2005
                  • 2068
                  • Yorba Linda, California
                  Fuse holders...
                  Try putting a small "O" ring around the ends of the fuse clips. Holds the fuses tight, even if one is broken off.
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  Custom security system
                  Stainless braid brake lines
                  • kicker42
                    • Jul 2005
                    • 7
                    • MI
                    Thanks I got it working and I picked up a for place fuse holder at Auto Zone that uses blade fuses I solderd all the conections and mounted it in the same place and it works great the bike even runs better.
