#3 n #4 better with prime
  • karateman
    • Aug 2002
    • 6
    • middletown oh.
    I was out on a short cruise when my xs lost half power (felt like it was running on 1 cylinder) and had to ride the clutch to limp it home. Well it sat for a couple days and I called the guy I bought it from to ask him if he had similar problems. He said sometimes the float would stick in #2 carb. So without hesitating I pulled off the carbs (not the easyest airbox assy.) and took them to the dealer in town. They did sell me a needle and seat , reworked and bench flowed them said they would work great. And they did when I fired the bike up in the parking lot. So I shut 'er down, drove across town, and put my bike back together again. Upon firing her back up the start button would not work so I jumped the selonoid and it ran (very pourly) but only on #1 and 2 . Cylinders #3 and 4 were not fired (a dummy test of spitting on each headder tube is the test I used) next I pulled a plug from #4 to test for spark . It was a very cold spark when I started the bike again .............Now my question is this can half a coil go bad ? Seeing how #3 and #4 are on two different coils . Or do Ineed to look for another problem ? Also the starter button is back to normal
    karateman
  • sixtysix
    No XS but XSive as can be!
    • 1958
    • Central New York State
    Half a coil can't go bad. Standard or special? It still sounds like fuel delivery, bad petcock? Try it on prime.
    Gary Granger
    • strom
      • 1577
      • Slovenia, EU
      I thaught that the coils go 1 and 4, 2 and 3.... at least mine were labeled like that way...
      Anyone knows sth bout that... for a 78?
      LP
      • oldnortonrider
        • 448
        Yer right; left coil works 1 & 4 >> right coil works 2 & 3 .
        JCarltonRiggs
        • karateman
          • Aug 2002
          • 6
          • middletown oh.
          well i took off side cover to look for damaged wires and found split vac advance hose! but i still had 3 and 4 cyl. not hitting so i rembered a reply of someone saying "sounds like a fuel problem .....try on prime" so i did and now i have all four cylinders back !!!!!!!!!!!!! i think ill be bald by the time i get this all figured out
          any suggestions!
          karateman
          • karateman
            • Aug 2002
            • 6
            • middletown oh.
            p.s. thanks to sixtysix and everyone else who replied
            karateman
            • sixtysix
              • 1958
              Are you sure that is an advance hose and not a petcock control vac line. If the vac hose to you petcock is bad, no fuel will come out, fix the line then try bike on run again....do you have a standard or special?
              Gary Granger
              • karateman
                • Aug 2002
                • 6
                • middletown oh.
                yes when i opened the side cover the hose was split at vac. advance but bike does run good on prime ill check petcock next
                karateman
