Stupid cover!
  • 81xsproject
    • 3185
    • Fortuna, CA
    Stupid cover!
    So I got this norton bike cover with the "heat proof" bottom section. Well, to make a long story short, after only a minute or two of running from bone cold, I put the cover on and the "heat proof" part melted on the #4 header and the muffler.
    So, does anyone have any suggestions as to how to clean the plastic off my chrome header?
    JC
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    Big chunks? Can it be froze with an ice cube and "fingernailed" off?
    WD40?
    Heat with a cigarette lighter and wipe away?
    I haven't a clue, but would like one.
    (Was wiping up some oil... and brushed against a hot pipe with an old towel. Did the same thing)
      • 5062
      I would try acetone. It eats plastics (and paint) for lunch. Problem is, it evaporates very quickly, so you might have to soak a rag and hold it on for a while before rubbing. VERY flammable stuff! If that does not work, try paint stripper. I have to assume you have chrome headers....
        • 7941
        MEK should clean it off quickly. Avoid the fumes and don't get it on your skin.
        • 81xsproject
          • 3185
          • Fortuna, CA
          what is MEK?
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
          • randy
            • Dec 2003
            • 4521
            Methyl Ethyl Ketone. or just Ketone. Nasty stuff, don't inhale it or you'll forget you're name
            Also known as "Cancer in a bottle". Dissolves almost anything except metal.
            I have seen it at some Home Depot stores in the paint dept.
            • piet
              • 75
              • nederland
              Wait with cleaning till after a while the plastic on the surface is totally burned up and use a metal sponge to whipe it easy away.
              xs1100 black 78 2h9 on the road
              xs1100 red 79 special with sidecar running on LPG and gas!
              xs1100 silber 79 2h9 o t r
              xs1100 white 80 2h9 Martini o t r
              xs1100 red 78 2h9 Martini o t r
              xs1100 black 80 special o t r
              xs1100 black 80 2h9 in parts sleeping
              xs1100 black 81sport for sale!sleeping
              xs1100 silber 81 2h9 i.p. sleeping
              xs1100black81midnspeciali.p.sleeping
              cbx1000 grey prolink 81 sleeping
              cbx1000prolink 83 in parts sleeping
              gsx750ex red 81 in parts sleeping
              • SG-Olli
                • Apr 2005
                • 118
                • Solingen, Germany
                I do not know if it is available with your self-cleaning ovens over there
                But I was told oven cleaning spray from your kitchen works pretty good.
                XS1100 and XS650- what do you need more?
                • corey
                  • Mar 2005
                  • 208
                  • Dexter, MO
                  I'd be careful with oven cleaner. I had a friend with a Ninja; she got some plastic on her aftermarket pipes. She then tried the oven cleaner trick and WHAMO! No more finish on her exhaust. :S
                  Corey J. Bennett
                  '79 XS1100SF
                  • prometheus578
                    • Aug 2004
                    • 4012
                    • Olympia , Wa.
                    Oven cleaner works quick... too quick. It splattered when sprayed and a drop landed on my polished aluminum.. marred it in about a second!
                    Next time, I'll spray the whole can into an old frying pan, and then dip in a brush and paint it where wanted.
