washer on oil drain bolt?
  • BauersXS11SF
    • Jun 2005
    • 27
    • Garrison North Dakota
    Hey,
    Changed oil on the XS last night and when it was all said and done I was dumping the used oil and found a washer, im "assuming" it goes on the drain bolt for the oil resivoir, but it might have gone on the filter cover bolt, can anybody tell me where exactly it goes?
    Thanks.
    BAUER
    Re: washer on oil drain bolt?
    Between the spring and the filter element.
    Originally posted by BauersXS11SF
    Hey,
    Thanks.
    • Phyxius
      • 47
      • Otsego, MI
      Skids is right, if in fact you forgot to put the washer back in the filter housing. The oil housing bolt has an o-ring to seal it. Otherwise, there should be a washer (teflon, I believe) that goes on the oil drain bolt which helps seal the opening. Otherwise, your oil will leak out and that will be a much bigger problem than a missing washer.
      If it doesn't have an engine, it's not a sport, it's only a game. (borrowed from strom)
      The idea is to die young............as late as possible.
      1979 XS1100SF Special
      • MartyA
        • 2148
        • NW PA
        The oil drain bolt has a washer? I didn't know that. Mine doesn't. What size is it?
        Marty in NW PA
        This IS my happy face.
        • randy
          • Dec 2003
          • 4521
          Marty,
          It's a common crush washer like on any oil drain plug, my parts fiche shows it as 15.7mm ID X 19.5mm OD and 2mm thick. You can probably pick one up at any good auto parts store. if you want to order it, here's the Yammi number:
          214-11198-01-00 GASKET (15.7-19.5-2.0)
          P.S. If you order the magnetic drain plug from Parts n More, it comes with the washer, and at every oil change you can see what sticks to the magnet, catching any problems early!
          • BauersXS11SF
            • Jun 2005
            • 27
            this a steel washer, not teflon or rubber which kinda got me thinkin that it goes on the drain plug, and reason number 2 is when I dropped the oil filter housing, It wasnt near the oil pan. but I did set the filter in there so it may have been stuck to the filter.
            BAUER
              Check out the shematics at http://www.yamaha-motor.com/sport/parts/home.aspx. Look for the oil cleaner. I suspect the washer you have goes between the filter and the spring inside the oil filter housing.
              • randy
                • Dec 2003
                • 4521
                Bauer,
                If the washer you speak of is 3/4" ID (19mm), then it is definitely the oil filter washer.
