Leather saddle bags
  • teck_mountain
    • Aug 2003
    • 128
    • Red Deer, Alberta, Canada
    Leather saddle bags
    I got a pair of leather saddlebags for my 79 xs1100 special. They seem to fit well, I have two inches clearance from the pipes and they are short enough not to cover the passenger foot pegs.
    But, the strap holding the pair together covers the seat mounting brackests. what should I do,........any one experiance this. I thinking cutting a slot for the bolts would fit through.
    Advice???
    Teck
    Tim Lowe
    "Teck"
    1979 xs1100 Special
    • 5073
    Mine have diamond shaped holes to access those bolts, but it is easier to lift up the bags to see the bolts.
    • xj11john
      • Jun 2005
      • 440
      • Lafayette, TN
      slots for bolts
      my saddle bags sound like yours and I cut slots, that worked for me, I just line up the bolt with the slot and then slid bag and seat forward and it works fine.
      '82 Xj1100j
      "Ride for the Son"
      John
      • Artic_rider
        • Apr 2005
        • 130
        • Grande Prairie, AB
        I'd agree with john...heart kinda sank when I tried to mount the bags, till my brain fart left me, and I pulled out the good ol' utility knife and slashed away
        80' Xs eleven special "The Tank"
        • Parr8hed
          • Aug 2003
          • 444
          • Southern Indiana
          had to do quite a bit of "clearancing" on mine. I found that a good pair of tin snips worked wonders.
          Travis Miller
          1978 E
          • DeanR
            • Jan 2005
            • 1499
            • Finger Lakes NY
            So running the strap that connects the two bags together Under the seat works well? Haven't known if my special would accomodate new soft bags AT ALL, looking at them at the dealer. What about clearance of the wheel. turn signal etc?
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • Artic_rider
              • Apr 2005
              • 130
              you might want to get some brackets for the bags, to keep them away from the rear wheel, or if your good with a mig, have access to a mig, you can build your own. As far as under the seat goes though, ya you should be fine, just trim it as needed to accomidate the seat bolts.
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                I've never seen brackets available anywhere, especially for a special. I'm also pretty sure it would mount differently than for a standard.
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                • don07tncav
                  • Oct 2004
                  • 358
                  • West Tennessee
                  http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
                  This guy states in his e-bay sales that he can custom make them. His prices look ok...
                  Don
                  99 Valkyrie Interstate named Drakker
                  81 XS1100 H Peppylebleu sold and gone to a good home
                  81 XS1100 Midnight Special Peppyledeux sold and gone to another great home
                  • Pat Kelly
                    • 3046
                    • Golden Valley, AZ
                    I now recall some bag stand-offs at Big Is Deuce. I forgot who's bike it was but he made them out of all thread, bent to the desired shape. They were covered with clear vinyl tubing to cover the abrasiveness of the threads.
                    Pat Kelly
                    <p-lkelly@sbcglobal.net>
                    1978 XS1100E (The Force)
                    1980 XS1100LG (The Dark Side)
                    1999 Suburban (The Ship)
                    1994 Dodge Spirit (Son #1)
                    1968 F100 (Valentine)
                    • xssiveone
                      • 766
                      • Windsor,Ontario,Canada
                      Standoff brackets are easy to make. I made some for my Kaw550, just used some flat 1/8" stock and bent one end to mount to the top shock bolt, and then bent the other end straight out to support the bags. Fastened the bottom of the bags to the bracket with a zip tie. Crude, but it does work.
                      I've seen lots of home made ones that used stainless steel rod bent to support the bags.
                      Brian
                      remembering the same thing!
