Timing curve and spark? Without data it's impossible to know. You'll know if it's right, though when you drive it.
HyperPak Performance Ignition
That hyperpak should be quality - made by kiwis - so no more! If that unit runs the timing 5 deg advanced over the whole range, then what's the difference to manually tweaking the advance 5 deg with a timing light? It's what I did on an old 78E. Noticed a slight kick at higher revs only. Too large a dwell time burns out ignition coils.
Re: hyperpak
Originally posted by jimg1au
hi
these sell on ebay in australia as well and the oldist yamaha they say it fits is the fj 1100.hope this helps
hyperpak
maximan
Brand new HYPERPAK PERFORMANCE IGNITIONS to suit 1982 to 1987 Yamaha FJ XJ 400 550 750 900 1100 bikes. These are a plug in replacement for the original unit and have a modified timing curve and inceased dwell time giving a better spark resulting in a much improved performance. NOTE:- The models are all different so when you bid please state year and model.
you are right it says it fits xj1100s
the guy who sells these is in australia and goes by the name of wayne gum.if it is fact and they do fit xj1100 they should fit xs1100 1981 mods.i will email him and fid some info out. will let you know the results
cheers
jim garvey
hyperpak reply
You asked:
"hi your ad states that the ignition will fit a 1982 xj1100 yamaha.the ignition module on this bike is the same as on the 1981 xs1100h yamaha. so will the ignition fit the xs1100 as well."
HI there, the 82 XJ models were using advancing TCI units which meant that they have no mechanical advance on the crankshaft. In 1981 they were usually just the mechanical advance on the crankshaft. If your 1981 model does not have mechanical advance on the crank then yes, we will be able to supply a unit to suit. Please let us know. Regards, Wayne
this is the reply i got from wayne hope this helps
Ok Randy
I got the 8 pin plug. The problem is the wires on the diagram don't match up to the wires on the unit. The 8 pin side shows 7 used. But the unit only has four wires coming out the side that should go into the 8 pin plug.
The schematic Wayne Gum sent is:
However the only wires coming out of the unit (for the 8 pin)are red, black, grey, and orange.
Any ideas where what goes?
Ok bear with me. I'm a little dense...that's why I'm a rockhead (geologist).
Yes the grey and orange are obvious. But then I only have a red and black...two wires left over...but the diagram shows there should be 5 more wires.
Odds are the red is + and the black is - but the diagram shows black/red...black/white...black/yellow etc. What?
Sorry for being so thick. You may have to spell it out for me.
Thanks for the patience
Ok I finally got around to testing this thing on my Maxim.
IT WORKED!!!!
But I had to change the pin configuration to match XJ. They had that all wrong but it was no big deal because their wires are color coded exactly like the XJ1100
When I got them all to match it fired right up and ran like a top. I have put through the paces yet but I think it's gonna be fine. I 'll let ya know exactly how it performs later.
