I took the wife for a spin tonight and my clutch slipped. I thought it might be the extra 110 lbs on the back. However it's never dome it before with her on back. I took it out by myself and it still slipped.
Yes I'm still running Mobil 1. I've put about 5000 miles on Zilla using Mobil 1 with no problems. So I dunno why that would do it now.
The bike has the original clutch....but it only has 11,800 miles of pretty easy ridin. Would a stock clutch be toast after 12,000 miles? Or could age (23 years) effect clutch performance?
I'm considering a Barnett Kevlar clutch with heavy duty springs. But first I'm gonna change oil tommorrow and really whack it to see if it still slips.
Thanks
Thanks
Worked fine after that. Due to wear in the plates, the lever and rod can loose it's clearance and get too tight!? Also, are you sure your cable is free sliding, not binding/sticking?
