Replacement Petcock gasket
  • Filter
  • Replacement Petcock gasket
    I replaced my petcock gaskets without going through the dealer...this is how!
    The dealer wanted 10-12 dollars for that little rubber gasket that goes in the petcock.
    The local hardware store wanted .39 cents for a neoprene rubber fender washer.
    I purchased several of these fender washers and experimented....
    If your old gasket is somewhat intact, you can use it for a size template, if not, a US quarter is near the same size.
    I used a leather punch to punch the holes at 12, 3, 6 and 9 oclock on the new gasket.
    press the new gasket into the petcock and check the fit, carefully trim with the leather punch or and x-acto knife.....
    re-assemble....
    total cost...under a dollar (US) for gaskets that Yamaha wanted 10-12 dollars each and required a two week order time on...total time invested...about an hour.....
    Good Luck and have fun!
    Doc
  • #2
    and i thought i was a cheap guy
    i finally brokedown and bought the rebuild kits ,they work great know
    lifes to short, so ride the wind
