Shifter Oil Leak Question
  • rockjok
    • 152
    • Montana
    Hi All,
    For a while I've had a bit of grunge accumulating on the case near the shifter. I can't positively pinpoint the oil leak but I bent the shifter last summer while high centered on a fallen tree. Thus the shifter seal is my primary suspect.
    Does anyone know if the shifter seal is one that can be replaced "easily" from the outside or will I need to do a bunch of disassembly?
    Thanks,
    Rob
  • Deni
    • Apr 2005
    • 36
    • Newark, DE
    Neutral switch?
    Hi, Rob. My leak was from the neutral "switch" underneath the shifter. Mine actually dripped a couple drops every day, and I guess when riding got blown back to make grunge on stuff down there. I think this is a common problem from the rubber or plastic gasket inside the "switch" getting shrunk down or cracked over the years from all the heat (not surprising). I bought a new one from BikeBandit.com for $15.52 and it worked like a charm. I don't know if the oil in the crankcase reaches up to the level of the switch hole, so I changed it out when I changed my oil. This probably could have been sealed with a dab of heat-resistant sealer both on the inside and outside of the center insulator because it's not really a switch. It's just a center contact that is insulated from the grounded housing that gets shorted when a grounded piece inside the shifter mechanism touches it in neutral. But the new one is nice and worry-free for $15. Don't know if this is your problem, but this is a pretty easy fix (screwdriver and socket wrench).
    -Deni
    Helmets save lives. Loud pipes hurt my ears.
    ___________
      That should be an easy fix, Rob. The seal inserts from the outside:
      • Smash
        • Aug 2010
        • 257
        • Denver, CO
        Two weeks vacation does NOT make a life.
        His: 2006 Ninja 650R, salvaged, 10k miles
        Hers: '82 XJ1100 44.4k miles
        • Smash
          • Aug 2010
          • 257
          • Denver, CO
          ARG why can't i reply to things normally????
          • DAVINCI
            • Jan 2011
            • 1048
            • Cedar Mountain, NC
            If you need the shifter seal, PM me your address. I got a bunch of them last winter NOS.
              it is an easy swap out for that. You can easily do it from the outside. I went and got a replacement seal for that for about 2.50 a couple months ago.
