Drilled brake rotors
  • grabberblue
    • Mar 2005
    • 57
    • Reseda California
    I did the drilled brake rotor conversion, THANKS to the XS11 forum!!
    I put on the rear disk only so far, I will put on fronts tomorrow. Looks much nicer, I used the template from Ken ( I think, i cannot find the link now to give credit)
    Anyway thanks again to the forum!!
    When I die I want to go in my sleep like my Grandfather,... not screaming like the passangers in his car!
  • grabberblue
    • Mar 2005
    • 57
    • Reseda California
    Got front rotors on, thanks again to Ken and the XS forum.
    Bike looks better with the drilled rotors. I cant wait to try them out in the canyons to see difference in performance.
      John;
      The biggest improvement the drilled rotors make is in wet braking. My first 11, a '78, I went through a stop sign in the rain with front and rear brakes on as hard as I could. after that, I had the front rotors drilled and didn't have any more "wet" brake problems.
      My current 11 has all three rotors drilled, and with the stainless lines, DOT 5 fluid, and rebuilt calipers I can lock up front or rear tires. I also used the pattern from this forum, and a cobalt drill bit!
      Ray
