Is it me or does my clymer manuel have a typo? It states that the carbs are numbered left to right starting at 1 which is okay, but... It also says to sync the carbs starting with 1 & 2 using what they label as screw "A". Okay... but the diagram shows "A" to be between 3 & 4. Too much gas fumes in my garage... I dunno.
Clymer book
Re: Clymer book
It really doesn't matter as long as they are equal vacuum when you are finished! =:-) BUT, you will notice that whenever you turn the screw for No.2 carb, No.1 will also be affected because it is tied to No. 2's linkage.
Originally posted by Glarusguy
Is it me or does my clymer manuel have a typo? It states that the carbs are numbered left to right starting at 1 which is okay, but... It also says to sync the carbs starting with 1 & 2 using what they label as screw "A". Okay... but the diagram shows "A" to be between 3 & 4. Too much gas fumes in my garage... I dunno.Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation. -
i looked in my year old chaparral catalog and found
xs1100 fours 78-81 and FJ1100-1200 84-93
but this could just be because its an older catalog, hopefully
maybe someone else knowsSSHHHHHHHHHHH (Cant talk now the Squirrels are Watching)Comment
Yeah, I realize the sych. process, but I saw the typo and wondered if anyone noticed the same. Didn't know if I was seeing things. Sometimes I spend a little too much time in the shop.
Oh wait... "Yes dear I'll be in in a moment"
"If it weren't for a budget I'd be bored."
Thom
79 xs11sf - Rented Mule
80 xs11sg
81 sr250t- sold to PainComment
"A" and "C" reversed
Hi, Glarusguy,
Yes, you are right. Under step 12 on page 51, "A" should be changed to "C". On page 53, step 13, "C" should be changed to "A".
-DeniHelmets save lives. Loud pipes hurt my ears.
___________
1979 XS1100FComment
So I am not slightly insane. I know it's common enough to have typos in any of the manuels especially in wire diagrams. I had to wire in a harness into my Saab and had tp make sure I had a pen handy the whole time. Anyway... Thanks for the replies."If it weren't for a budget I'd be bored."
Thom
80 xs11sg
