rotor/stator
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    rotor/stator
    I changed the rotor/stator cover on my bike last night and when I ran it this morning is smelled and felt pretty hot. I'm not sure how hot it got before I changed it; just never really paid attention to it.
    It seemed like a easy change out and the only thing i was concerned about was the gasket. Since mine tore and I did not have a new one I just put the cover on and went with it.
    So, would that thickness of gasket have anything to do with a tolerance issue for clearence in there? Any other suggestions as to why it smelled/ felt hot?
    I'm going to pull it off again to be sure but I felt like it all went back together correctly.
    1980 LG
    1981 LH
  • ratbyk
    • 994
    • Sooke BC
    Hope you didn't pinch the wires.
    Ken/Sooke
    • dpotter58
      • Aug 2004
      • 1866
      • Southern Maryland
      A tiny little piece of the old gasket was inside between the rotor and stator. I pulled it out and everything works fine.
      1980 LG
      1981 LH
        • 7830
        So double clean and double check on engine, triple clean on carbs??
