Speedometer info / pictures
  • jchigbee
    • Mar 2003
    • 48
    • Lamar, Colorado
    Long a go I found some info / pictures of a disassembled speedometer from an XS that showed the internals, the few gears inside, etc. I have been looking for a couple of hours now and cannot find it. I am wanting to take my used one I bought apart without screwing it up, for cleaning and lube with white lithium lube. Can any one please tell me where to find this article again, maybe it was an offsite link? PLEASE HELP.
    Thanks, JC
    JC
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    I found this post... hope it helps
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      2 quick notes to add to my original comments.
      Speedo needle is connected directly to the "bell" on a shaft; the spiral spring is not involved except to control (calibrate) the movement of the 'bell'.
      Speedo needle 'jumping' was finally traced to a broken speedo drive plate in the front axle. This plate has 2 fingers; one had broken off, must have been that way for a while until the 2nd broke and speedo died completely. I replaced the plate and seal and speedo is steady as can be.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • jchigbee
        • Mar 2003
        • 48
        • Lamar, Colorado
        Thanks a lot for the info I really appreciate it and should be exactly what I needed, I will work on this project over the weekend.
        Thanks again, JC
        JC
