Hi All. been a while since ive been here cause of work. But finally got my manuel and clutch kit and am installing it tomarow.
However due to tinkering that should have been done before, i now am at a major delima and am going to ask for help like i should have done long before
all right after the breakdown i lost alot of patiance with my 1980 special, i thought it was the clutch (wishful thinking) but a noise that sounds like a gear grinding which i thought was just the engine spining the clutch and nothing was grabbing, (forgive me im new) anyway the noise sounded like it was coming from the shaft drive or transmission, so tonight when i got to pull the clutch cover off i thought id spin the back wheel to see if anything moved well nothing did and the noise kept sounding like it was coming from the SD so i pulled the rubber boot back a little and grabbed the barand spun the wheel and it spun but the rod connecting the Final drive to the transmission did not
now could this be coming from the transmission or the Shaft or is it still possible its the clutch(OH PLEASE GOD LET IT BE THE CLUTCH)
If you guys could help it would be really Great
Thanx
now could this be coming from the transmission or the Shaft or is it still possible its the clutch(OH PLEASE GOD LET IT BE THE CLUTCH)If you guys could help it would be really Great
Thanx
, it sounds more like his middle gear section has fried. He says he was able to turn the drive shft at the Ujoint, and the rear wheel DID turn, so that eliminates the Final Drive for now. But he said the shaft that goes to the transmission from the Middle Drive/Ujoint area didn't turn. That sounds like a frozen/fried Middle drive that may have gotten the splines broken so that the Engine/tranny can spin, but it spins in the middle gear so not transferring to the Drive Shaft, and all the associated grinding noises in the middle drive.?
Good luck!
