R1 or something front end
  • auxtian
    • Sep 2002
    • 136
    • Berkeley, NSW, Australia
    Anyone know if the front end from say an R1 would work on an XS or are we too heavy
  • Dennyz
    • 1151
    • Olympia, Washington
    Nope, the R1 front end will not bolt on the XS frame. The top steering bearing on the XS's is too small.
    DZ
    Vyger, 'F'
    "The Special", 'SF'
    '08 FJR1300
    • Ken Talbot
      • 4251
      • Revelstoke, BC
      Haven't you sorted that out yet, Denny?
      Ken Talbot
      • auxtian
        • Sep 2002
        • 136
        Not even with a big hammer????
        • Dennyz
          • 1151
          Because of the steering head issue and widening the rear swingarm and shaft drive for a bigger tire, I have decided a custom frame is the way to go. Haven't start on that yet.
          DZ
          Vyger, 'F'
          "The Special", 'SF'
          '08 FJR1300
          • mainlylinux
            • 211
            • Michigan
            Denny, any update on the front end/swingarm mods?
            if you had a machine shop at your disposal could you make the r1 front end fit the stock xs frame?
            Dan
            Home of ENIAC
            Kinda like a MANIAC with 2 letters difference & a computer on board
              • 7818
              Dan, I think the problem is the center post on the front end is a larger diameter than the steering head on the XS. You would need to cut and weld a new head stock on the frame. The other way would be to weld a new post on the triple clamp, and fit it to the XS frame.
              Ray
              • mainlylinux
                • 211
                • Michigan
                I see.
                Dan
                Home of ENIAC
                • auxtian
                  • Sep 2002
                  • 136
                  How about the XJR1300 front end
                  • mainlylinux
                    • 211
                    • Michigan
                    BTW auxtian, your bike is sharp!
                    You must be thinking along the same lines as me with the forks, huh?
                    My forks are "sticky" and it sucks. I'd love to have some new hardware up front.
                    Dan
                    Home of ENIAC
                    • scoobes
                      • Jun 2003
                      • 454
                      • formby,which is near liverpool england.
                      i think that a xjr front end will fit i think mike farnworth in the uk done one,or it could have been a xj 900 not sure now
                      • pggg
                        • 1609
                        • NZ
                        Any front end, 50mm solid ones or 45mm and/or upsidedown. Would bolt on easy. 4 - piston calipers and floating wavy discs and 17inch front preferably.
                        • mainlylinux
                          • 211
                          • Michigan
                          pggg - do you have any plans to do a conversion?
                          Dan
                          Home of ENIAC
                          • Trikerneil
                            • Dec 2005
                            • 141
                            • Wareham, Dorset, UK
                            I've got a H*nda VF front end in mine complete with 16 inch wheel.
                            Triking - it's a way of life!
                            www.trikenest.co.uk
                            • mainlylinux
                              • 211
                              • Michigan
                              Trikerneil, I've looked over your website. Thanks for sharing all that info!
                              Your trike is awesome.
                              Dan
                              Home of ENIAC
