tried to start this a.m. turned over like half way and just click now push started runs great . how do i test to see if is starter or some other problem .. thanks all
starter trouble
starter trouble
Joe Bjordahl
“speed don't kill it’s the sudden stops”
Yamaha xs1100 are addictive
1979 XS1100S
1981 XS1100 MIDNIGHT
1982 XS1100S DONER BIKETags: None -
Hey FloridaJoe,
I editted your thread subject, from STATOR to STARTER trouble!! Could be many things, like Maximan said, clean all connections, pull wires off battery, starter solenoid, etc.. You can also bypass the starter switch, if it cranks strong, then you know it's not the starter, but could be the switch/solenoid!?
T.C.T. C. Gresham
thanks all it was the starter solenoid got one and in and running took about 10 min it is good to work across the street from a bike salvage yardJoe Bjordahl
1979 XS1100S
1982 XS1100S DONER BIKEComment
Now, just for something to do, you should carefully open up the old one, clean it up inside, give it a wee squirt of electrical contact cleaner, and put it back together for a spare. You'll have a spare, and also the experience to be able do it again on the side of the road if the need should arise. Pull this off on someone else's ride and you'll really be a hero!Ken TalbotComment
Joe,
Nice to know there is another XS'r near me. I am just west of you. Jazzrat is another local up in Delray Beach. If you need help, let me know and I will see what I can do for you. I am no great wrench but I have been getting by.
Which bike salvage yard are you referring too in your post?Owned by a pair of XS11's. An 80 Standard and a 79 Special.Comment
pompano patsJoe Bjordahl
1979 XS1100S
Thanx, I will have to get by there and check it out.Owned by a pair of XS11's. An 80 Standard and a 79 Special.Comment
