My Electrical problems last month
  • Jdwags
    • 232
    • Rathdrum, Idaho (nort of Post Falls)
    I got a number of emails asking so i wanted to update those that I missed regarding my woes of electircal porportions.
    This is all in time for Deuce next weeekend, Ill be arriving Sat, and have to head home Sunday evening...
    after all UPS needs me to deliver all those xs parts from member to member...
    I'm back on the road!!! It ended up that they had spliced an "extra hot
    wire" coming off the accessory side of the ign switch, prior to the fuse,
    and it wasn't used in the spagetti bucket, but was a male bullet connector
    (not even taped)...
    apparently it shorted to ground, and caused enough of a power draw to
    hasten the corrosion in the switch connections at the white plug with the
    spade connectors... cutting off all power..
    I pulled that apart cleaning the connectors (unaware of the male bullet
    sitting in there welding itself)... and got power...
    as i got the bike running, all of a sudden it started smoking...
    (welding does that u know), and so i shut off the ign switch, and
    observed smoke from the side cover as well... he had also when bypassing
    the fuse panel, decided no fuse was necessary on the 30 amp circut so he
    put a splice of 18 ga wire in it.. well - that acted as a fusable link and
    literally melted.. stopping further damage.
    I found and fixed the bullet connector that was shorted, and put an in line
    30 amp fuse and holder in the ign circut line, and recleaned all the
    connections..
    including reconnecting the other in line fuses he had put in..
    The results,
    Better power to everything, brighter lights, signals, indicator
    lights, faster starter, NO SMOKE...
    I tell you, even some of his splices were corroded.. even the ones he
    soldered... so i nipped of a bit more, and respliced, still got a few
    connectors to go, but i tell you.. it is nice being back on the road.
    jeff "Wags"
    Bothell, Wa
    79sf mongrel
    79sf rusty
    79 partsbike almost complete
  • sksxs1100
    • 331
    • Bridge city,TX (Beaumont area)
    jeff... best bet is to go to West Marine, or some other boating supply house and get Anchor brand marine heat shrink. It has a sealant inside of it. I use the stuff every day at work and have yet to ever have a problem with it.... ok off to work on the new 650 again...
    Shawn
    78 XS1100E "Black Rat"
    78 XS1100E Parts
    www.hotrod1972.com
