52mm or 54mm carbs?
  • fountainbiker
    • 26
    • Novato, CA
    See, I am new at this...
    Correctamundo! I didn't mean lean, I meant rich... pu... and it's been that way since I got it 3 years ago. I'll hafta play with the image/server deal, all that's new to me too... so much to learn, so little time.
    Jerry F.
    <t///><
    CMA & Champions for Life
    1978 XS1100E Stnd
      • 5062
      Brock, it begs the question, "which one won the race?"
      Originally posted by brock
      then hit enter. if i did it right, my turtle pic should appear above.
      • brock
        • Aug 2004
        • 78
        • Tallahassee, FL
        That poor little guy. I found him in the middle of the road on some back highway in the middle of Georgia somewhere. i pulled over and brought him over to the field, and he wouldnt even come out to have his picture taken.
        i thought about bringing him with me, but i didnt want to subject him to the shock on another bumpy hour or two in the dark in my trunk. imagine the mess you'd make.
        I pulled over at the same spot on my way back, and no sight of him, so i guess he made it out to whereever he was heading.
        1979 XS1100 Special
        • brock
          • Aug 2004
          • 78
          • Tallahassee, FL
          OK. I've got my air box off, and am thinking about putting my new cone shaped filters on.
          question: what about all those 3 hoses that are attached to the front of the air box? one goes down to the engine, and two to the carbs.
          what am i do do with those after I've gotten rid of the air box?
          1979 XS1100 Special
            The larger hose is a crankcase breather. The two smaller hoses from the carbs are float bowl vents. All 3 need to vent 'to atmosphere' so you don't want to plug them. You could just tie them up somewhere up under the tank. You would be better off finding some small filters for the ends of each hose that would still let them breathe, but that would keep bugs and dirt out.
            • wildbill
              • Feb 2003
              • 346
              • western NC
              The big hose is the engine breather hose, you may want to put a small filter on it like a uni filter.They either push on or clamp on. The 2 small hoses are carb vent hoses.Fix them so that they run up first then drop down below the carb float bowels.That is basically all you need to do to them. Hope this helps.
              Bill Harvell
              • fountainbiker
                • 26
                • Novato, CA
                Originally posted by rneal55555
                Yer probably gonna have to rejet and whiler not hard it can take a few times before ya get it right. In XS 650's the cheap EMGO (I think) cause problems. There are work arounds but I found it easier to go back to the stock airbox.
                Hey Russ,
                You say the EMGO are cheap, what about TACO brand? If both are cheap, what brand is a good brand to get? Thanks!
                Jerry F.
                <t///><
                1978 XS1100E Stnd
                • rneal55555
                  • Aug 2003
                  • 210
                  • Milton, NH
                  I'm not sure I I had a set on my XS650 when I got it. On the 650 they case a disterbance in the airflow going into he carb. You don't notice it at lower rpm's but when you get up around 5500 rpm the motor starts breaking up and the RPM's top out just below 6k. Some guys fix it by puting extensions in between the filter and the carbs allows the air to settle back down. K=N's don't do it but htere about 60-70Bucks verses 10 or less for the EMGO's. I guess you get what you pay for. I just went back to the factory airbox and stock filters because I had the box. I've never done it on the XS1100 and have never see much written about it so it probably doesn't matter. If I were you and was=nted to make the change I'd try to look at both pods and see if I could detect a difference in quality. Then take the time to make sure a got it jetted right. It's not really hard but it can take a couple of shots the are some good tech tips that explain it. Again it's not hard but can be time consuming. Good Luck with it if you make the change.
                  Russ Neal
                  Milton, NH
                  04 GL1800 ABS
                  04 Kawasaki Concours(Sold)
                  99 Royal Star Venture(Sold)
                  80 XS1000 Special(Sold)
                  83 XJ750 Midnight Maxim(Sold)
                  80 XS1100G(Sold)
                  81 XS 650 Special(Sold)
                  • CMA1
                    • Jul 2003
                    • 114
                    • Ontario, Canada
                    my 79 Special works great with the EMGO filters.
                    I did have to up the mains to 142.5 .
                    '79 Special
                    • Jerry
                      XS & TRUE XJ GURU
                      • 3023
                      • Elma, IA.
                      BTW, the '80 - '81 XS and '82 XJ has 54mm inlet bell, takes a different individual filter than the ealier XS. From Cycle - re- Cycle catalog for Pod filters, the 54 mm (2 1/8 inch) filters fit the following bikes:
                      GS750/850/1000/1100 '80-'86 * FJ1100/1200 * XS/XJ1100 '80-'82
                      Their web page is at:
                      Jerry Fields
                      '82 XJ 'Sojourn'
                      '06 Concours
                      My Galleries Page.
                      My Blog Page.
                      • Dennyz
                        • 1151
                        • Olympia, Washington
                        Jetting Tips
                        DZ
                        Vyger, 'F'
                        "The Special", 'SF'
                        '08 FJR1300
