Fuse Block Mod
  • mixelpix
    • Sep 2004
    • 237
    • Utah
    Fuse Block Mod
    Is this the JCWhitney part referred to in the Tech section?
    XS11.com > Modifications > Battery & Electrical
    SKU# ZX037115W
    $25.99.
    Looks like it. Just wanted to make sure cause the SKU# is different and the note about there not being many models which have multiple independant in and out leads.
    Thanks!
    Patrick Kennedy
    p.s. think I might get one for my lil' xs400f as well...
    Your Mileage May Vary
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    I have a 4 fuse set-up on my E but that one would work too.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • randy
      • Dec 2003
      • 4521
      Pat Kennedy,
      $25.99 is double what Pep Boys sells 'em for. They're made by Littlefuse. Check out my fuse box mod for the Littlefuse part# here:
      Randy's XS11 Page
      Click on the XS Resto Tips button.
        Hey Randy and Pat,
        I used the fuse block from Pep Boys also, had 5 fuse slots! I noticed that the one in JCW as well as mine stated that the maximum fuse to use was only 15amps. The turn signal circuit uses a 20amp. Now, I converted my turn signals to LED, and so didn't have that kind of draw on that circuit, so I had no problems in using a 15amp fuse, but if Pat stays with the OEM bulbs, will that be enough for his turn signal circuit without overheating it??
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          I ordered mine from on-line. The same one used in the tech tip.
          My E is using 2x10a for headlight and ign, 1x20a for turn, and 1x30a for main. I've no problems so far (eXScept for the other morning).
          My LG still has the OEM glass fuses. I removed each one and wiggled and tugged on each of the holders. All appear in great condition (for now). I'll eventually get a 5 blade-fuse holder (move the one from the left side to the right with the others).
          Pat Kelly
          • mixelpix
            • Sep 2004
            • 237
            • Utah
            I think the 20-10-10-10 should be okay. The ad copy says "Rated up to 90 amps (15-amp maximum per fuse) when connected in series" - and the one on the JCW site has 6 slots. So ijust figured 6x15=90, but who knows. My 400 came w/a modified fuse block and the mains (also 20A) housing melted out in the middle of a ride across the Bay Bridge...
            Course I guess if you found out the hard way you could just reconfigure to another slot for the ride home
            • randy
              • Dec 2003
              • 4521
              Doesn't add up.
              Maybe they meant 90 amps when connected in parallel. Think about it. If you connected 6 15-amp fuses in series, one of them will blow when you exceed 15 amp current draw, opening the circuit. Doesn't make sense.
                • 7737
                Patrick;
                My Eleven came modified already. the PO had put four of the yellow wire blade fuse holders in place of the fuse block. They are available at Kragens or Ace Hardware, both local stores. They are rated to 30 amps, so you can put all 4 in, and keep the original fuse rating.
                Cost is about $2.00 each, so they are also MUCH cheaper than JCW.
                Ray
                • mixelpix
                  • Sep 2004
                  • 237
                  • Utah
                  Ray
                  I think I have found a solution - saw some at Marine West this weekend too, shoulda picked em up...
                  • jeffe
                    • Oct 2004
                    • 393
                    • Westerville,Ohio
                    The original fuse block on my 78E fell apart this summer. I was close enough to an auto zone that I was able to walk and get the blade type fuse holders to replace it. Took less that an hour, walking included, and less than $10 bucks. I had the same thing happen years ago to my 82 650 Seca. She had over 60,000 miles on her by then. Replacedthe fuses the same way as a "temporary" fix, with the intention to get a new fuse box. Never did, never had any problem with it, so why fix what ain't broke.
                    78E ... Gone but not forgotten
                    2006 Kawasaki Concours....just getting to know it
