Drive Shaft?
  • Drive Shaft?
    I had the frame, calipers and everything else powder coated. I removed all the bearing's and all but did not remove the drive shaft from the swing arm.
    Powder coat is heated to 410 degrees and I'm worried about the needle bearing in the u-joint, I looked today at it and the book's and can't figure out how to remove the drive shaft from the swing arm. The books show a c-ring keeper on the splined shaft up inside the u-joint. Hardly any of the splined shaft is visible inside the u-joint. I'll be darned if I can see the damn thing to remove it, had my son-in-law look (with much better eyes) and he could not see it either.
    After the keeper is installed doe's it pull back into the u-joint? Or doe's anybody know if it is actually there on a 78E?
    There's always a way, figure it out.
    78XS11E
    The keeper is there on all models, and you don't have to remove it to get the yoke off, in fact, you can't remove it untill you do get the yoke off. Pry the yoke off with a couple of screwdrivers, or use a gear puller if you want. The keeper sits in a groove on the end of the drive shaft, and fits inside the yoke.
    Brian
    remembering the same thing!
      The shaft simply pulls out. The trick is figuring out how to grab it so you can give it a good yank. All that grease on the grabbing end makes it a bit tricky.
      Ken Talbot
        Thanks guy's, I just hate to start pulling and prying on thing untill I know for sure.
        78XS11E
