XJ speedometer ?
  • fxrer
    • Aug 2004
    • 241
    • Bethlehem, PA 18017
    XJ speedometer ?
    My buddy has been slowly replacing parts on his '85 Maxim 700 XJ, damaged in a gravel wipeout this fall. He has most everything but a speedometer, which was pretty well crunched. All the OEM Yamaha sources show the speedo is no longer available. Can't get the bike inspected (here in PA) without a working speedometer.
    Anyone know of a source for new, used, or repaired speedometers? (These are the white face type)
    Thanks
    fxrer
    Rick
    '80 SG
    '88 FXR
    '66 Spitfire MK II
  • mitch
    • Oct 2002
    • 934
    • fredericton new brunswick canada
    Bicycle speedo
    A lot of guys here use a Byclce speedo never seen them in Canada but They have a magnetic pick up that goes to the front wheel and measures reveloutions. Theyare even more accurate than the stock one so they say. Might be a cheaper better alternative. Mabye someone with knowledge on which i speak will give u more advice. ....MITCH
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
    • ratbyk
      • 994
      • Sooke BC
      Bicycle Speedo
      I use one and have seen several other bikes with them. I bought mine from the local bike shop here in Sooke. They had several models in stock. Cost was about $40.00cdn. Easy enough installation and appears to be quite accurate. I installed it on my Honda Ascot which had a dud speedo. Only problem that I can report is that because it has LCG display, you cannot read it while wearing polaroid sunglasses.
      Google "www.vetta.com" and check out their web site. It will cover all current models and the features.
      Ken/Sooke
      78E Ratbyk
      82 FT500 "lilRat"
      92 ZX11 Temptress
      • fxrer
        • Aug 2004
        • 241
        Hey guys, thanks for the tip. I checked out that web site. Even though it won't match his tach, it's at least a way for him to get the bike back on the road. I'll keep looking for one on E-Bay, but at least he has another option.
        Thanks to all the knowledgeable members, this forum is the best!
        fxrer
        Rick
        '80 SG
        '88 FXR
        '66 Spitfire MK II
          • 7862
          Here's another link that may be helpful:
          http://www.mikesxs.net/mikesxs_parts.php?category_id=8
          • fxrer
            • Aug 2004
            • 241
            Marty,
            That's a great link! - I had MikesXS bookmarked but never thought to look for gauges there. A couple speedos look suitable, although small. I wonder if they use a cable, or electronic input?
            Thanks for the tip
            Rick
            '80 SG
            '88 FXR
            '66 Spitfire MK II
              Other sources
              Hey there Fxrer,
              JCW also has generic mechanical ones at this location:
              Gauge set
              Parts-n-more has similar gauges here:
              Partsnmore gauges, scroll to bottom of screen
                • 7862
                I expect the speedos listed at the Mike's XS site are cable operated. The late model XS650 has the same speedometer as the XS1100 Special. The XS650 also has a cable operated tachometer, so I expect that is what Mike is selling.
                  The 650's will work, I put a used one on my 81 Special due to mine breaking the odometer at 950miles!!! It only goes to 120, but that's 35 more than my stock 85, and still faster than I've ever tried to get it to go!!!
