My charger is a 12 volt charger that can trickle charge (2amps) or 10 amp charge. It does not tell me when the battery is fully charged. I just assume after 2 hours at 2 amps that it is charged.
82 xj1100 starting problem
I pulled my plugs out. Each was black, some were a little wet, I cleaned them, and put them back in. The engine started right away. Now everything I have read say you cannot adjust the Carb mixture. Is this true, I somehow think they may be fouling very quickly. This could be the problem.Comment
yes,look at the electrodes of your 4 bougies,the gap may not be more than a normal steel sawblade thicknes.
and look if the earthwire connected too the engine makes a good contact
xs1100 black 78 2h9 on the road
xs1100 red 79 special with sidecar running on LPG and gas!
xs1100 silber 79 2h9 o t r
xs1100 white 80 2h9 Martini o t r
xs1100 red 78 2h9 Martini o t r
xs1100 black 80 special o t r
xs1100 black 80 2h9 in parts sleeping
xs1100 black 81sport for sale!sleeping
xs1100 silber 81 2h9 i.p. sleeping
xs1100black81midnspeciali.p.sleeping
cbx1000 grey prolink 81 sleeping
cbx1000prolink 83 in parts sleeping
gsx750ex red 81 in parts sleepingComment
