Air Box Drain Hole
  • nashville_bill
    • 605
    • Nashville, TN
    Air Box Drain Hole
    The last time I had my air box cover off I noticed that the drain hole is on the carb side of the filter. Doesn't that mean that there is unfiltered air going into the carbs? Is there supposed to be some sort of check valve in the drain hole?
    Bill Murrin
    Nashville, TN
    2005 DL1000 V-Strom "WOW"
    2005 FJR1300 Newest ride
  • don07tncav
    • Oct 2004
    • 358
    • West Tennessee
    Mine is the same, there is a drain hole but nothing in it. I thought it was strange and spent 15 minutes looking for a dropped item on the barn floor!!
    Don
    99 Valkyrie Interstate named Drakker
    81 XS1100 H Peppylebleu sold and gone to a good home
    81 XS1100 Midnight Special Peppyledeux sold and gone to another great home
    • piet
      • 75
      • nederland
      hay,the is a cap there with a hole in it and a piece of foam that filters the incoming air,just put there a something that will do the same.
      xs1100 black 78 2h9 on the road
      xs1100 red 79 special with sidecar running on LPG and gas!
      xs1100 silber 79 2h9 o t r
      xs1100 white 80 2h9 Martini o t r
      xs1100 red 78 2h9 Martini o t r
      xs1100 black 80 special o t r
      xs1100 black 80 2h9 in parts sleeping
      xs1100 black 81sport for sale!sleeping
      xs1100 silber 81 2h9 i.p. sleeping
      xs1100black81midnspeciali.p.sleeping
      cbx1000 grey prolink 81 sleeping
      cbx1000prolink 83 in parts sleeping
      gsx750ex red 81 in parts sleeping
      • Dennyz
        • 1151
        • Olympia, Washington
        I threaded a bolt in the hole to block it off.
        DZ
        Vyger, 'F'
        "The Special", 'SF'
        '08 FJR1300
          If the drain hole is within the filter perimeter (inside), the air coming in will be filtered. I can't remember if it is located there...
          • piet
            • 75
            • nederland
            no the little drainhole is in the part where the air is already been filtered,so better do something about it if you're worth a xs1100:
            • mitch
              • Oct 2002
              • 934
              Air Hole
              Sounds like a good place to put a nitrous nozzle lol............MITCH
              Doug Mitchell
              82 XJ1100 sold
              2007 Stratoliner 1900 sold
              • Pat Kelly
                • 3046
                • Golden Valley, AZ
                I went out and looked at the stock airbox on my 78.
                The only opening other that the inlet snorkle and the 4 boots to the carbs, is on the bottom of the access cover to the air filter.
                This opening (with a piece of foam in it) is in the center of the cover. This area is the fresh air area before the filter. The airflow goes from the snorkle under the seat to the center of the filter, through the filter, then out to the carbs so all the debris ends up on the inside of the filter (opposite of how most filters work).
                If yours is like this then no junk is being sucked into the engine through the airbox.
                Look real close at the design of the airbox and you'll see what I mean
                Pat Kelly
                <p-lkelly@sbcglobal.net>
                1978 XS1100E (The Force)
                1980 XS1100LG (The Dark Side)
                1999 Suburban (The Ship)
                1994 Dodge Spirit (Son #1)
                1968 F100 (Valentine)
                • piet
                  • 75
                  • nederland
                  You must be wrong ,you can't see wat is inside,so take a look at my LPG conversion project and you know what i know
                  http://www.motor-forum.nl/forum/topic.php/77536/last
                  By the way the streetdirt from the frontweel goes right thrue the cillinders airhole's to the drainhole
                  • Robert Haller
                    • 356
                    • Atlanta, GA
                    The hole can be useful if you ever have a float stick and gas drains into the airbox. I had one stick for the first time at the SE rally and gas drained out of the hole that would have otherwise stayed in the airbox. I didn't realize a float was stuck until I saw gas coming out of my bike.
                    Robert
                    79 SF
