Xs1100 Floor boards & foreward controls
  • excess11
    • Oct 2004
    • 256
    • Rockville Md.
    I am trying to put a set of floor boards and foreward controls on my 78' E Xs1100.The problem I am having is with the bolt for the front motor mount, after installing the brackets the bolt is to short. The factory bolt is 295mm long x 10mm diam. I will need a bolt about 325mm x 10mm. That is one big bolt. I can not find anything even close to that. To make things worse the bolt is stamped grade "8". I thought about threaded rod but that would only be mild steel not a hardened bolt. What ideas can you give me Thanks for the help!
    Dan ( A.K.A.- MacGyver )
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    if you are talking about the upper front mount
    with 1 long bolt to both sides
    you could try putting in 2 shorter bolts
    like the lower front mounts
    just keep an eye out for flex
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      When I put my case guards on the XJ, I replaced the metric top long bolt with an SAE bolt. Found one that was right length and diameter at the local hardware store.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
        Re: Xs1100 Floor boards & foreward controls
        I have been using an "all thread" rod for about 4 years on one of my xs11's. I meant to find a longer bolt on ebay, but it seems that they only are provided with NOS case guards. I am sure you can get one from a bolts and fasteners specialist dealer. Gee, I hope my engine doesn't fall out!!! :-/
          Here are some threaded rods and flange nuts from a Machine Shop Industrial Supply company catalog that I have, called MSC Direct . I've ordered some tools and rods/pipes from them with ease!
          I would venture that they are a bit stronger than the basic rods you'd find in your local hardware store!?
          The prices I'm quoting are from their 2001/2002 catalog, but I'm sure they aren't far off! I don't know all of the steel types and descriptions, perhaps some machinists can comment on the types and strengths of these materials.
          HTH, T.C.
          Alloy Steel threaded rod-NC=national coarse thread
          4140B-7 Chormium molybdenum alloy good hardness high strength meets ASTM A-193 B7 Specs
          3/8"-16 diam/thread 3foot length
          #06056741 $3.23ea
          Stainless Steel 304(18-8) and 316 types
          for 3/8"-16 3foot length
          listed respectively 304 and 316
          #06052146 $3.99ea #64815814 $6.22ea
          Flange nuts:
          Ledloy Heat treated cyanide black oxide finish
          #82428038 $1.92ea
          303 Stainless Steel Certified ISO 9001
          #06818827 $4.23ea
            I'll say this about the threaded rods. If you go this route, cut it long enough to put a washer and two nuts on each side. Unlike the OEM solid bolt, You do not have to slide the whole thing through to remove case guard bars, you simply undo the end nuts. I don't think that the threaded portion in the middle does the engine mount rubber ANY good, although I haven't witnessed any damage, yet (never had to remove it to see).
              Maybe you could find some very thin bushings to place over the threads where they pass through the rubber mounts. That would protect them from damage caused by the threads chewing into the rubber due to vibration. Now that I think of it, don't the mounts have a metal bushing in them already?
              • xj11yamaha
                • Jun 2004
                • 80
                • Northen Michigan, USA
                i beleive that they do il have to check my motor, it's setting on the work bench so, EASY ACCESS to see the truth! I'll check then post back soon
                Current Projects:
                -1982-1992 Yamaha Ezgo XJ1100 Maxim Project
                  Seems to me that the cross tube of the front, upper mount had recesses to fit over the bushings/sleeves in the rubber mount.
