One of the hoses between the oil cooler on my bike and the oil filter plate has formed a small leak. I decided I should replace both lower hoses. BTW, my oil cooler which I think is a kerker, has some kind of device between the oil cooler and plate which I have no idea what it does. I pulled off the hose after much effort and the hose seemed a little brittle near the ends. Also, when I squeezed the hose to pull it off, the hose stayed in the shape of the squeeze. Almost like as if I was squeezing plastic pipe.
When I read what I could off of the hose, it indicated it was for up to 200 psi. Do you need a hose able to withstand that much pressure or could I go to one more suitable for fuel pressure. That would be hose rated for up to 50 PSI? And any idea what the thing is between the oil cooler and plate?
