I read here somewhere about the process of removing the reserve lighting unit or just bypassing it.I own a 78E and would like to do this.Also be able to enable the headlight on off switch.I read here where one could use relays to make the headlight brighter.Can you help me out?Thanks and take care.
Questions concerning removing
It's not all that bad, but some of the problem could be in the aiming of the headlight. To find if it gets brighter by bypassing the RLU, then just run a jumper wire from the battery to the low beam port that the bulb is plugged into, either the green or yellow wire, I don't remember, and observe the brightness. Do it with the engine running. Then with the engine still running, just remove the jumper and see if the light changes any. If you have a schematic, then it should be easy to bypass the RLU.
Everything so far on my bike is stock except for the headlight witch came off of a Honda V45.The headlight wattage is 60w-55w and on a curvey road at night it is just plain scarey.When I first got this bike it had a round headlight on it{not stock}but the wattages are the same.My first XS didn`t have the brightest lights on it either.I just want to inprove the lighting as much as I can.Seems like with all the different circuts that are involved there has to be a power drain.The best way to do things is keep it simple.Thanks.Bill Harvell
suggest
On the XJ the headlight bulb is a removeable bulb. think it's called e-4 or something like that.Anthoo,i replaced mine with one of those hyper white bulbs man does that thing shine brite.And not all yellow looking either.1982 XJ 1100
Brightness
The '78E has a fixed bulb, but in '79 and up there is an H4 which you can get from JCW in a variety of wattages from 60/55 (stock) through 100/55, 100/80 (my choice) to 130/90, which will suck your battery out from under the seat! I am running the 100/80 and properly aimed I have very few cages giving me the brights and Boy, does it ever light up the road! And the're cheap! The trick is, you won't find these in the Motocycle catalog. Look in the latest car catalog on page 138. The alternator on the XS seems to keep the battery up with the 100/80, but 130 watts is a little much. Christopher. "The Gimp"Christopher. "The Gimp"
Thanks.I have thought about changing to a higher wattage bulb but was concerned about the power drain.I can change the bulbs on my bike easily so that is no problem.Say a 100w-80w works best?It is worth a shot.The stock lighting is not the best but if replacing the bulb makes that big a difference I will try it.Thanks.Bill Harvell
Hey there WildBill,
I, too, was disenchanted with the OEM headlight on my 81. I haven't bypassed any circuits, but I did replace my old bulb housing with all of those diffusing ripples in the front glass with a Clear Lens front, with new reflector base inside. I went fancier than the standard Clear lens converter(that is DOT approved!), and got the one with the lighted colored accent ring around it, to match my colored accent ringed aux lights I have also mounted!
They are made by Pilot, here's the JCW Link:
Pilot Clear Lens Headlight Conversion kits:Accent Rings
I ordered the 7" round for my Special, they only come in a PAIR! JCW used to have the Plain Non-accent ringed ones as well, but didn't see them in the search list! I'm running the regular 65/55 watt bulb in the main light, and a pair of H-3's 55watt in the Aux lights, wired to the aux fuse with relay and switch on handlebars, so when I want extra night lights, have them, but otherwise I'm not draining my battery.
Are you going to the Ga. Rally, I'll be there and you can see them in person!T. C. Gresham
brighter lights
Wildbill.
I did some tests on my bike. not enough voltage to light. so i exsperimented with a relay. took voltage from 11.5 to 13.5. use a volt meter to track voltage to headlight. my bike showed very little voltage drop through rlu. their are many writings about this very problem.
try webbikeworld.com.
and maddelectrical.com.
try using search engines.type in headlight relays for motorcycleswhen you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
graybird78
80 sg (old faithfull)
TC thanks for the tip.I know of a auto parts place near were I live who might be able to help me.I have a retanglar headlight which is on the bike and also a round one that I can put back on if have to.I also might be able to find something else but I might have to change the lens.I would like to attend a rally but money is very tight right now.I have pretty well given up on ridding this year and have preped my bike for the winter.Maybe next year I hope. Thanks.Bill Harvell
Re: brighter lights
Originally posted by graybird78
Wildbill.
try using search engines.type in headlight relays for motorcyclesBill Harvell
The headlamp on MIYAMI is pretty bright. Even brighter when SWMBO rides with. Good thing for the Vetter faring as I can adjust the aim depending on load. I thought that I had a problem years ago before I learned about the adjustment knob. I couldn't see but mabee 20 ft ahead on a dark nightS.R.Czekus
1-big XS patch
1-small XS/XJ patch
1-XS/XJ owners pin.
Just do it !!!!!
Originally posted by Czekus21
The headlamp on MIYAMI is pretty bright. Even brighter when SWMBO rides with. Good thing for the Vetter faring as I can adjust the aim depending on load. I thought that I had a problem years ago before I learned about the adjustment knob. I couldn't see but mabee 20 ft ahead on a dark nightBill Harvell
You could always put a light bar with two additional driving lights. Kinda like the Hogley roadkill. I've seen this done on an XS and it looks pretty cool. If I didn't want to keep the original astetics of my bike, I would deffenetly put one on. Mabee my next project bike.S.R.Czekus
1-big XS patch
1-small XS/XJ patch
1-XS/XJ owners pin.
Just do it !!!!!
