The XJ has only 2 marks on the timing shaft rotor, "T" for timing, top dead center, and "C" for Cam chain adjuster. Yes, follow the instructions for XS using the "C" mark!
79SF "The Teacher" . . .basket case! History shows again and again,
Yep, page is from the Yamaha service manual. Two notes...if you are turning the crankshaft clockwise and overshoot the mark, DON"T BACK UP the crank. Go ahead another revolution to line up the marks. Other point is do not overtighten the stopper bolt or nut. Torque figures are not much more than finger tight. The adjuster housing is aluminum, and over-tightening will strip the housing threads. Tkat is working on a process to put a heli-coil in the housing to prevent/repair stripped threads. The heli-coil is much harder and a lot less prone to stripping out. Over-tightening can also nick the sliding bolt that moves forward to take up the slack, making it not slide properly.
I adjust my cam chain at every oil change, about 3K miles. Only takes a couple minutes once you have done it a time or two.
Jerry Fields
'82 XJ 'Sojourn'
'06 Concours My Galleries Page. My Blog Page.
