PartsNmore - Front Master Cylinder
  • buickyouth
    • Apr 2004
    • 202
    • Chicago, IL
    I heard a rumor. That these will work on XS11s but standards only. Not specials.
    Can anyone confirm this?
    I am a rhinoceros and my skin is three feet thick.
    //////////////WARSENAULT/////////////
  • dragxs11
    • Jun 2003
    • 519
    • Reno, NV
    Hey there buick, Thats true if you have the stock bars on the special. You'll notice that the fluid reservor is slanted. Thats because when mounted on the stock bars, it sits flat. Standard models with shorter "flat" bars came with a reservor that is flat to coencide with the lack of angle on the bar. I went from stock bars to shorter ones, so I had to get a different master cyl. so that I could keep from sucking air. Look at this pic and you'll see what happened to the stock master cyl. when mounted on standard type bars. 2nd pic shows a master cyl. from a standard.
    1980sg-Stocker-- Sold
    1980sg- Cruise Missile- Sold to RODS454
    1990 ATK 604- Ditch Digger
    2005 BMW K1200S- Killer Bee
    2005 Suzuki GSX-R 1000- trackbike
    • dragxs11
      • Jun 2003
      • 519
      • Reno, NV
      You can see in this older pic that the stock bars are curved and the stock master cyl. reservor sits flat.
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        The stock master cylinder from a Virago should work on the specials. It looks identical the the PnM cylinder but is on the special bars. If nothing else it may be slanted too much.
        If the resevoir is filled then it dosen't matter if it's tilted or not as long as it's sealed. I turn my bars to the left when filling mine and I know fluid would come out if it wasn't capped.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          Ok, the pics didn't open for my 1st post. Looking at your flatter bars, the PnM cyl will be perfect for it. I have one on my E.
          Pat Kelly
            • 7942
            I believe you can purchase the same master cylinder from MIKE'S XS for less money and he pays the shipping. It's listed as a dual disc upgrade for the XS650.
            I'm interested in the VIRAGO option. What was the last year for the VIRAGO with the buckhorn bars? Is the master cylinder for that bike still available new from YAMAHA?
            • buickyouth
              • Apr 2004
              • 202
              • Chicago, IL
              bucked buckhorns
              My XS has handlebard that are (or are eerilly close to) stock standard bars. I imagined that this might be the issue. Currenltly, I've been having front brake issues. Other than the spooge hole fix, I suspected that the MC didn't sit very flat and might be causing some of the problem. Perhaps it is.
              • Pat Kelly
                • 3046
                • Golden Valley, AZ
                The Virago I looked at is a 96 (my wifes XV1100). I do have another MC from PnM that I bought for wifes XS750 and haven't installed yet. I would sell it for the $74 it cost me. Still brand new in the package.
                Pat Kelly
                • beechfront
                  • 673
                  • midwest
                  i bought the partsnmore one and it worked fine for 4,000 miles. brakes are squishy now, but i don't fault the MC.
                  • sinter
                    • Aug 2004
                    • 15
                    Hey, great pic/post. I actually just put flatter bars on my LG over the weekend and encountered the slanted reservoir problem. Looks like I have to add this aftermarket MC to my to-buy list along with Randy's SS brake lines (which it appears will have to be special ordered for the shorter bars).
                    Speaking of flatter bars -- I put these relatively cheap Bike Master (I think) black Daytona bend bars on mine...about 15 bucks -- what shorter clutch cable did you replace the stock one with? I've just routed mine above and across the speedo. It works, but is a short term fix.
                    • beechfront
                      • 673
                      • midwest
                      mine is a special by the way.
                      • poorboy112597
                        • Jul 2003
                        • 80
                        • Chicago
                        I have an 80 special with that master cylinder and it works perfect.
                        Adrian
