Spark Plugs, which ones?
  • CRXSi90
    • Jun 2004
    • 400
    • Madison, Wisconsin
    My motorcycle is running NGK BR6ES right now.
    The manual calls for NGK BP6ES.
    See the difference? I have R, but P is called for.
    BR6ES
    BP6ES
    If I read their info right, the plugs are the right size and all, with slight differences.
    BP6ES plugs are Japanese Industrial Standard height. Also, they have a projectile tip (slightly extending, I assume?). Those are what I should have.
    BR6ES plugs have resistors. Thats all. Thats what I have
    So who cares? Which one should I get? Do my plug wires already have resistors? Do I need resistors for the bike to function (not interfere with other ignition stuff or whatever)? I have a radio on the bike. That would be interfered without a resistor, right? Do I have a resistor, or do I need this self-resistored plug?
    LOL, I'm sure I sound frantic and like I've lost my mind! The last part may be true.
    Thanks so much, guys! I don't know what I'd do without you!
    kevin
    '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
    '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
  • pgg
    • Jul 2003
    • 394
    CRX, that BR plug is a 2-stroke resistor plug. A BPR plug is a 4-stroke resistor plug. The projecting tip is better for 4-strokes because the intake valves' fuel/air flow cools the plug.
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I'm running Bosch Platinum 4218 in mine (with Dyna coils).
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • UncleSpot
        • Jun 2004
        • 383
        • Home: Stockton, California Shop: Lodi, California
        ...and I'm running Bosch Platinum 4216 in mine - '80XS1100SG stock except 4-into-1/Kerker/SuperTrapp
        Pat, what's the difference b/w 4218 and 4216?
        __________________
        Ron Veil
        <Ron_Veil@yahoo.com>
        1980 XS1100SG
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          I think mine are one step cooler than yours. I have the Jardine 4 into 2 exhaust, K&N filter in aribox, Dyna coils (42,000 volts comapred to 12,000 volts for stock coils), Silicone wires and MSD plug caps. I have my air/fuel adjusted slightly rich (using a colortune). My exhaust pipes aren't blued but I lack power on the few occasions I ride above 5-6,000 feet elevation.
          Pat Kelly
            Hey there 90,
            Yes, the plug caps have resistors built into them, ~5kohms. Theoretically you can run Non-resistor plugs, but like you said, you may get more RF interference from them on your radio!
            Follow this link for a list of plugs that you can use on your XS!
            List of Plugs Tech Tip
