Serviced? - - -
- - - in the agricultural sense, that is. You betcha were!
Tire swap, new valve & balance $20 flat rate tops if you bring the wheel in and it's your own tire. Most shops take some off that if you bought the tire from them instead of saving ~$40 by getting it on the net. And they should swallow their own incompetence rather than try billing you for it.
If you really do have a tubeless tire with no tube in it mounted on a tube-tire rim there's good odds it will go flat on you.
Even I could most likely ride a rig to a safe halt if the rear tire went flat but the cost & incovenience of getting the thing home to fix it will far exceed that of the "free air".
Fred Hill (with a can of "fix-a-flat" anna jack in my sidecar trunk & 3 tubeless tires on my rig in) S'toon.
