polishing fins
  • grifff
    • Jul 2004
    • 117
    • Cedar City, Ut.
    polishing fins
    I've been polishing the fins on my motor. Went and bought some blue magic and mothers polisher. My heavens what a time consuming project. Is there an easier way to polish the fins? Tried using 3m green pads, but it still takes as long.
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    Griff, Did you try an Aluminum file first. then emery cloth to fine paper then steel wool.
    • grifff
      • Jul 2004
      • 117
      • Cedar City, Ut.
      I haven't maybe i'll give something like that a try.
      • Winterhawk
        • Jun 2004
        • 684
        • Missouri
        If you file a very slight bevel or an angle on the top of the fin it will give the impression of a larger fin looking down on it. More to polish with really good results.
        • grifff
          • Jul 2004
          • 117
          • Cedar City, Ut.
          gonna bust out the file now and give her a try
          • grifff
            • Jul 2004
            • 117
            • Cedar City, Ut.
            ahhh, My fins aren't smooth. I'm leaving peaks and vallies. I can see no matter what i do its gonna take awhile.
            • newmaac
              • Dec 2002
              • 369
              • San Jose, CA
              I too, am in "the polishing" mode. I have been using 400 grit, then 600 grit wet paper, with soapy water, and following-up with Mothers polish.
              Tonight I bought a polishing kit for a Dremel tool. I plan to use the various polishing tips in a small pnumatic die grinder that I have, to get between the fins etc...
              I will let you know how it turns-out.
              Mike
              1980 SG "Angus"
              • grifff
                • Jul 2004
                • 117
                • Cedar City, Ut.
                Hiyas Newmaac, How does the soapy water work with the sand paper? I have used sand paper, steel wool, 3m green pads, and mothers, and blue magic(mothers seems better). It's late dont want to fire up the compressor, but i'm gonna try a few diff things hehe. Let me know how how it goes. I only have a dremel and die grinder. Thinking about cutting out little circulars out of green pads and putting them on the dremel???
                • Winterhawk
                  • Jun 2004
                  • 684
                  • Missouri
                  Somtimes if the file isn't cleaned off regularly it can score the fins. Maybe the file is to course or something. Try keeping it clean and use light pressure.
                  • newmaac
                    • Dec 2002
                    • 369
                    • San Jose, CA
                    Grifff. You don't want to use steel wool on aluminum, so I'm told.
                    Something about steel fibres sricking in the surface of the aluminum and causing early tarnishing, or something like that.
                    If you use wet/dry sand paper to cut through the clear coat, and remove the heavier oxidation of the aluminum, it makes for easier work to just polish with the Mothers.
                    Adding a little liquid soap to a bowl of water, and frequently dipping the paper seems to help the process along.
                    The Mothers has carnuba wax in it, so, if it is applied once or twice a year, it should not be necessary to ever put the clear coat back on.
                    The little buffing pads for the dremel are pretty cheap. It probably is not worth screwing around, trying to make them.
                    I bought a kit at Orchard Supply Hardware. It has several mandrels, different sized buffing tips, a few mini wire brushes and some polishing compound, and it only cost $12.
                    Good luck
                    Mike
                    1980 SG "Angus"
                    • grifff
                      • Jul 2004
                      • 117
                      • Cedar City, Ut.
                      silver leaf
                      Hey Hey, I read a thread in another venue. Guy was using something called rub-buff silver leaf. I got a diff. brand, maybe not as good(don't know) but wow this stuff kicks ass. I think i will use it most in hard to get places. Shines right up kind of a temp buff, thread i read though he said it lasts for awhile.
