Just curious. Will a 79 Standard exhaust system fit onto a 79 Special Frame?
Standard exhaust on a Special
I am a rhinoceros and my skin is three feet thick.
//////////////WARSENAULT/////////////Tags: None -
The length between the header flanges and the head may be different. Hopefully, you can get the nuts on the studs. Maybe it is the other way around ang the studs will be extra long for your needs, in which case you may need regular nuts (long version) instead of hex-head nuts. You may have to fabricate hangers at the sides also because, I think the side brackets are different. I have not done what you are doing, but I know there are some differences.Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
Did the exhaust fit, then?
Ben1985 Yamaha VMX12n "Max X" - Stock
Formerly:
1982 XS650
1980 XS1100g
1979 XS1100sf
1978 XS1100e donorComment
I used standard headers with Harley sportster mufflers on the Mongrel. They worked great. It's not exactly what you were asking about but it's close.Originally posted by ae7f
Ben
I think the only difference between the bikes in this respect is there the muffler support bolts to the frame. If you did this swap, you'd probably have to add a mounting strap.
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
