HALOGEN light question
  • beechfront
    • 673
    • midwest
    picked up a sealed, halogen replacement today.
    does anyone know if this is going to pull more juice than a regular bulb?
    i don't like to make changes right before a trip - but i really would like to have some more light.
  • TheDjost
    • Jul 2003
    • 153
    • Montreal, Qc
    Just check the # of watts. Divide that by 12 and it will give you the # of amps.
    -Justin
      Hey there Beech,
      The Special's OEM headlight bulb is rated at 60watts max, so if your new halogen is higher, then, yes, it will draw a few more amps, but as long as you don't have too many other accessories and you're running at cruising speeds/rpm's you should have no trouble powering it even if it's a 80/100 watt bulb.
      • beechfront
        • 673
        • midwest
        thanks guys.
