pulled stud
  • bigun_78
    • Jul 2004
    • 4
    • Oklahoma
    pulled stud
    Hello Im new to the board and have a quick question. I recently purchased an XS1100 special from a local shop. I was riding it and all the sudden it started makin a horrible noise. After getting it home I inspected the headers and noticed one of the them to be loose. I tried to tighten it but to my dismay the stud pulled out of the head. Apperently the previaus owner had JB welded the stud into the head. I drilled out the JB weld and chased the previous threads, inserted a heli-coil but it still fit loosely. Any suggestions would be greatly appreciated
    81 xs1100
    85 v65 Magna
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    I think red Loctite might work to hold in the helicoil. Should fill in .003 of clearance.
    • bigun_78
      • Jul 2004
      • 4
      • Oklahoma
      thanx ill try that if the jb weld and heli-coil dosent hold
      81 xs1100
      85 v65 Magna
      • xssiveone
        • 766
        • Windsor,Ontario,Canada
        Or, just drill and tap for a larger size stud.
        Brian
        remembering the same thing!
        • DEmily
          • Jun 2003
          • 220
          • Kansas City, MO.
          You could try a keensert. This is a solid metal tread insert that goes in much like the helicoil, but it had hooks or teeth that you set with a hammer and it holds real good!
          79 XS1100 f (BIGDOG)
          80 XS650 Special
          85 KAW 454 LTD
          Dirty Dan
          • bigun_78
            • Jul 2004
            • 4
            • Oklahoma
            I dont know if i can go to a much larger stud. Where can I find a keensert. Thanx for all the help.
            81 xs1100
            85 v65 Magna
            • mitch
              • Oct 2002
              • 934
              Studs
              On my xj, i removed all the stock studs bought some 3/8 threaded rod and drilled and tapped all the stud holes and installed 3/8 studs and double up on the nuts. I had to enlargen the flange holes a little but it worked fine. Why? you might wonder, cause 2 of the original ones were broke and the new ones are much stronger. Just thought i would mention it . $3.00 total cost and 3 hrs labour! HTH..............MITCH
              Doug Mitchell
              82 XJ1100 sold
              2007 Stratoliner 1900 sold
              • DEmily
                • Jun 2003
                • 220
                • Kansas City, MO.
                I found them at one of my local hardware stores, but most of them do not carry keenserts. My hardware store called them threaded steel inserts. I did find that most any nut and bolt company or a company that deals in fasteners carry them. You can also do a search on the internet for keenserts and you will find plenty of them. Good luck!
                80 XS650 Special
                85 KAW 454 LTD
                Dirty Dan
