deglazing cylinder walls
    • 5062
    Is there any benefit to using emery paper on the cylinder walls while the head is off? I am not doing rings. I think the compression is good other than the valves (repairing). If this can be done by hand rather than honing it, what grit paper should I use?
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Re: deglazing cylinder walls
    Only hone a cylinder if you are installing new rings otherwise you'll wear out the rings you have faster. They've already worn together for a tight fit, don't disturb it.
    Geezer
      • 5062
      Re: Re: deglazing cylinder walls
      Thanks! If you can't trust a geezer, who CAN you trust?! :-)
      Geezer
      • ratbyk
        • 994
        • Sooke BC
        De-glazing
        I second Geezer on this one. Without replacing the rings never disturb the bedded in seal that already exists between the rings and the cylinders. Since you cannot buy new standard size rings be careful in there. Simply wipe them out with a clean lint free rag and put on a light coat of oil.
        Ken/Sooke
        • ratbyk
          • 994
          • Sooke BC
          De-glazing
          Further on this de-glazing question. There are some who believe, (and I'm one of them) that the carbon ring that forms around the top of the cylinder. Do not remove it. Thinking that you are doing a good thing while cylinder head is off, many people will clean this carbon off the cylinder wall. Don't, possibly loose stuff but the main hard formed ring should remain unless you are going to change the rings.
          The reason for leaving it alone is that it protects the top ring during initial combustion. This layer of carbon shields the top ring just as combustion takes place and while heat and pressure are at their maximum.
          Ken/Sooke
